AUDIOPHONICS BT60W HiFi USB Amplifier Bluetooth 3.0 2x30W
4.6 / 5
Reference : 9926
34,90 €tax incl.
29,08 € tax excl.
-Version V2 available for the Audiophonics BT60W USB DAC Amplifier-
The Audiophonics team offers you this elegant and compact Bluetooth 3.0 Amplifier.
It has been designed around a Black Anodized Aluminum chassis and has a volume control.
Equipped with two amplifier modules TPA3110D2bridged dual mono delivering up to 2x 30W, it will very quickly become the ideal companion of your Smartphones, Tablets, PC, etc ... It also has a small amplifier headphone with its integrated circuits XPT4809 of the manufacturer Xptek.
hehas a 3.5mm jack input. You can connect it to your speakers via the HP terminal outputs or enjoy your audio files via the 3.5mm headphone jack.
This small device is full of positives and versatility, indeed the latter can also serve as DAC USBvia its micro-USB port.
Audio Test and Testphonics BT60W by Qobuz
Features:/ Strong>
  • Texas Instruments TPA3110 x2 Amplifier Modules
  • Headphone amplifier with specialized circuits type XPT4809
  • Bluetooth Receiver 3.0 APPOTECH
  • Range: 10m
  • Power: 2x 30W under 4 Ohms
  • Hp Protection
  • Input: Jack 3.5mm
  • Outputs: speaker terminals, 3.5mm jack for headphones
  • On / Off switch
  • Volume control
  • Power Supply: 12V DC 5A included (DC Jack 5.5 / 2.5mm)
  • Chassis Anodized Aluminum Black
  • Dimensions: 78x70x38mm
  • Weight: 100g
  • Package: 3.5mm jack to RCA stereo cable, 3.5mm jack to 3.5mm jack cable 1m, 1 user manual, and its 12V power supply / adapter
11 reviews
Exeptionnel à ce prix !
C'est vraiment bluffant ce qui sort de cette petite boite. Branché sur des enceintes made in "chez moi" à partir de HP Focal 130CVX, ça dépasse la qualité de mes Bose Companion 2 connectées à mon ordi. Les possibilités de connections sont très intéressantes (Jack, Bluetooth). Et surprise, j'ai découvert depuis peu que je pouvais le brancher en USB car il a aussi un DAC intégré (ce qui n'est pas décrit dans la documentation). Par contre j'aimerai bien connaitre les caractéristiques de ce DAC, Audiphonics si vous me lisez ;-)
En conclusion, cet ampli produit un son bien équilibré,détaillé, dynamique et tenant bien les basses. Alors à ce prix n'hésitez pas un instant.
This review has been posted for AUDIOPHONICS BT60W HiFi USB Amplifier Bluetooth 3.0 2x30W
BT 60 W
Bon ce n est pas un SHINDO ni un CELLO ! mais moins de 40 euros pour ce petit ampli ! Branché sur des Q Acoustic 1010 mais aussi sur des GAIA MINOR et des PHY ( 21 et 30 ) il se débrouille très bien dans ma grande pièce . Je ne regrette pas mon achat .
déçu
Après avoir lu les commentaires ici et le test de Qobuz, j'ai été très déçu par la piètre qualité sonore du produit. Sur l'entée aux (et rien de mieux en bluetooth, peut-être même pire), avec pourtant une bonne source (un streamer Cambridge et des FLAC) et des bonnes enceintes (des Totem Mite, puis une paire de biblio B&W), la scène est très plate, les timbres pas forcément agréables, notamment dans les hauts médiums... sans attendre un son magnifique, on pouvait espérer mieux après ces avis dithyrambiques.
Bonjour,
Vous êtes le premier à nous faire un tel retour sur ce produit. Nos essais sur des systèmes très variés ont toujours donnés des résultats bien au delà de nos espérances.
qualite
Qualité des matériaux utilisés. Qualité musicale ( pour le prix !) .Acheté les yeux fermés .
Très bon
Que demander de plus pour le prix.
Testé sur son entrée jack avec des KLIPCH R-14M, une pêche d'enfer.
