AUDIOPHONICS TAS-SW45 Amplifier 2.1 TAS5630 Class D 2x 45W + 175W 4 Ohm Black
Reference : 14610
69,90 €tax incl.
58,25 € tax excl.
Audiophonics TAS-SW45
Integrated amplifier 2.1 TAS5630 Class D
This integrated amplifier is based on a Class D architecture with a TAS5630B PurePath ™ HD chip. It is characterized by a high quality reproduction with a large power reserve in a very compact product.
It delivers up to 2x 70W + 280W under 4Ω with perfomances perfectly suited to an affordable and easy to set home cinema installation. It is an ideal solution for driving your passive stereo speakers with passive subwoofer.
Three potentiometers located on the front allow to respectively adjust the volume of the subwoofer channel, the adjustment of the treble (tone) and the volume of the stereo channel in order to find the most pleasant configuration. The preamplifier and volume control stage is controlled by an operational amplifier AD827 offering excellent dynamics and a signal rich in details (THD + N <1% & SNR >100dB).
It easily connects to your source via a 3.5mm female jack input. A male jack 3.5 to male jack 3.5mm is included with the amplifier.
Caution : the power supply is not included with this amplifer unit. Please refer to the "Accessories" section on this webpage to find a suited power-supply.
TypeIntegrated amplifier
Channelsx3 (2.1)
AmplifierTAS5630
ClassD
Inputs1x Jack 3.5mm stereo
Outputs3x Speaker terminals
Power(Power supply DC 36V) 2x 45W + 175W @ 4Ω THD 10%
(Power supply DC 45V) 2x 70W + 280W @ 4Ω THD 10%
THD+N<1%
SNR100dB
Input impedance20KΩ
Output offset voltage<150mV
Volume controlOui (AD827)
Bandwidth20Hz-20kHz
Power supply20-48V (not included)
Power connectorJack DC 5.5/2.1mm
Dimensions146 x 148 x 42 mm
Weight850g
InputJack 3.5mm
OutputSpeaker terminal
