The BlueSound PowerNode 2 is both a Digital Amplifier capable of delivering 2x60W under 8 Ohms and a Streamer Multiroom Hifi Network Drive.
KEY POINTS:
By buying this product you get 89 loyalty points
Network reader 32bit 192kHz streamer multiroom 2x60W 8 Ohms
The Bluesound POWERNODE 2 is a 32-channel 192Khz digital streamer multiroom amplifier to play your HD files and Streaming services like Deezer, Spotify and Qobuz./ P>
The Powernode 2 amplifier incorporates the Hybrid Digital concept of the sister NAD brand renowned for its legendary musicality as well as the latest features and extensive connectivity. This amplifier is capable of driving a wide range of HiFi speakers with 2x60W over 8 ohms under a low distortion.
The Streamer powernode 2 amplifier with its 32 bit 192KHz DAC decodes without fail the high-sampling rate (192KHz) HD (lossless) files. The very high computing power of the ARM Cortex 9 1 GHz multi-core processor brings a level of reactive user comfort without slowing down for the control and the diffusion of the music in streaming in all your rooms. It has the same Multiroom features as other Bluesound devices.
The POWERNODE 2, like all Bluesound drives, drives from your smartphone or tablet with a free IOS or Android application.
The control interface brings together all your sources, on cloud, on your computer, your smartphone, a NAS or almost all other sources via analog and digital inputs. Streamer from Wi-Fi or from Bluetooth, or connect it to your Ethernet LAN.
Whatever the source, Bluesound will be your companion High fidelity high resolution available until the resolution Studio Master 24/192.
Video test in English
You can browse your music collections from the Bluesound app on your smartphone, tablet or computer. The free Bluesound app is available under iOS and Android.
Connectics / Connectivity | |
Wireless | Bluetooth aptX / WIFI 802.11 b / g / n |
Connectors | Ethernet RJ45 Gigabit / Mini-USB Type-B (maintenance) / USB Host type-A (USB stick, hard disk) / Optical audio input / 3.5mm mini jack / RCA output for subwoofer / Headphone output |
<inputs/ Td> | Ethernet RJ45 Gigabit / Mini-USB Type-B (maintenance) / USB Host type-A (USB stick, hard disk) / Optical audio input / 3.5mm mini-jack |
Exits | RCA output for subwoofer / Headphone output / Speaker terminals |
Miscellaneous | |
Dimensions | 220 x 70 x 190mm |
Weight | 1.72kg |
Consumption | 12W |
Color | Black |
Included Accessories | Power cable / Ethernet cable / Optical cable Toslink to optical mini-jack |
Input | Optical |
Input | RJ45 |
Input | Jack 3.5mm |
Input | Bluetooth |
Input | WiFi |
Output | Speaker terminal |
Output | Subwoofer |
Output | Jack 3.5mm |
Color | Black |
