BLUESOUND POWERNODE 2 Hi-Fi Streamer 32bits/192KHz 2x 60W / 8 Ohm White
The BlueSound PowerNode 2 is both a Digital Amplifier capable of delivering 2x60W under 8 Ohms and a Streamer Multiroom Hifi Network Drive.
KEY POINTS:
  • Class D 2x60W 8 Ohms
  • DAC 32bits 192kHz
  • ARM Cortex 9 1Ghz Processor
  • Multiroom
  • Hybrid Digital Amplification by NAD
By buying this product you get 89 loyalty points
Reference : 10565
899,00 €tax incl.
749,17 € tax excl.
Bluesound PowerNode 2
Bluesound PowerNode 2 White
Network reader 32bit 192kHz streamer multiroom 2x60W 8 Ohms
The Bluesound POWERNODE 2 is a 32-channel 192Khz digital streamer multiroom amplifier to play your HD files and Streaming services like Deezer, Spotify and Qobuz./ P>
ARM Cortex A9
The Powernode 2 amplifier incorporates the Hybrid Digital concept of the sister NAD brand renowned for its legendary musicality as well as the latest features and extensive connectivity. This amplifier is capable of driving a wide range of HiFi speakers with 2x60W over 8 ohms under a low distortion.
JOIN THE STREAMING REVOLUTION.
The Streamer powernode 2 amplifier with its 32 bit 192KHz DAC decodes without fail the high-sampling rate (192KHz) HD (lossless) files. The very high computing power of the ARM Cortex 9 1 GHz multi-core processor brings a level of reactive user comfort without slowing down for the control and the diffusion of the music in streaming in all your rooms. It has the same Multiroom features as other Bluesound devices.
A high quality audio environment.
The POWERNODE 2, like all Bluesound drives, drives from your smartphone or tablet with a free IOS or Android application.
The control interface gathers all your sources on cloud, on your computer, your smartphone, a NAS or almost all other sources via analog and digital inputs. Streamer from Wi-Fi or from Bluetooth, or connect it to your Ethernet LAN.
Whatever the source, Bluesound will be your companion High fidelity high resolution available until the resolution Studio Master 24/192.
Back bluesound powernode 2
Video test in English
Control your HiFi system from your smartphone or tablet
You can browse your music collections from the Bluesound app on your smartphone, tablet or computer. The free Bluesound app is available under iOS and Android.
application bluesound
SpecificationsAmplificationHybridDigital Amplifier by NAD ElectronicsPower2x60WSNR- 110dBTHD + N-0020%ProcessorDual-Core ARM Cortex A9 1GHzSupported file formatsMP3, AAC, WMA, OGG, WMA-L, FLAC, ALAC, WAV, AIFFDAC32bits 192kHzSampling frequencies32, 44.1, 48, 88.2, 96, 176.4, 192kHzQuantification16bits, 24bitsCompatible Online Music ServicesWiMP, Rdio, Slacker Radio, Qobuz, HighResAudio, JUKE, Deezer, Murfie, HDTracks, Spotify, TIDAL, Napster, RhapsodyInternet radioTuneIn Radio, iHeartRadioUser interfaceFree Android and iOS apps + commands on the top of the devicesystemscompatible operating systemsWindows Vista 7, 8, Apple Macintosh OS X 7-10Connectivity / ConnectivityWirelessBluetooth aptX / WIFI 802.11 b / g / nConnectorsEthernet RJ45 Gigabit / Mini-USB Type-B (maintenance) / USB Host type-A (USB stick, hard disk) / Optical audio input / 3.5mm mini jack / RCA output for subwoofer / Headphone output<inputs/ Td>Ethernet RJ45 Gigabit / Mini-USB Type-B (maintenance) / USB Host type-A (USB stick, hard disk) / Optical audio input / 3.5mm mini-jackExitsRCA output for subwoofer / Headphone output / Speaker terminalsMiscellaneousDimensions220 x 70 x 190mmWeight1.72kgConsumption12WColorWhiteIncluded AccessoriesPower cable / Ethernet cable / Optical cable Toslink to optical mini-jack
InputJack 3.5mm
InputWiFi
InputRJ45
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
ColorOther
ColorWhite
The BlueSound PowerNode 2 is both a Digital Amplifier capable of delivering 2x60W under 8 Ohms and a Streamer Multiroom Hifi Network Drive. KEY...
