DAYTON AUDIO HTA100 Hybrid Tube Class AB Amplifier Bluetooth 2x65W 4 Ohm
The perfect solution for enjoying the warmth of a tube amplifier, the Dayton Audio HTA100 features a hybrid design, combining modernity and vintage. It combines the characteristic sound of vintage tube amplifiers with the modern convenience of solid state amplifiers.
By buying this product you get 35 loyalty points
Reference : 17560
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 16-04-2025.
Dayton Audio HTA100
Dayton Audio HTA100 Amplificateur à tubes hybride Class AB Bluetooth 2x65W 4Ω
The best of both worlds
The debate often rages over whether tube or transistor amplifiers produce a better listening experience. The HTA100's hybrid design puts an end to this debate by exploiting the best of both worlds. The amplifier uses both the classic Class AB architecture design while employing tubes in the preamplifier circuitry.
Flexibility & Power
With a power of 2x65W RMS under 4Ω, the HTA100 offers a nice power reserve for the integration of a robust HiFi system. It also benefits from the convenience of Bluetooth 5.0 connectivity, allowing you to stream and control your music remotely, from a smartphone or tablet for example.
Versatile connectivity
With its RCA auxiliary input, phono input and USB-B, optical and coaxial digital inputs, the Dayton Audio HTA100 is versatile, allowing it to be connected to many source devices. In addition to its speaker terminals, the Dayton Audio HTA100 offers a subwoofer output on RCA and a headphone output in 6.35mm jack format.
Product typeAmplifier
InputsBluetooth 5.0
1* USB-B
1* Optical Toslink
1* Coaxial
1* Stereo RCA(AUX)
1* Stereo RCA (phono input)
OutputsSpeaker terminals
1* RCA subwoofer output
1* Jack 6.35mm headphone output
Amplification typeClass AB
PreamplificationTube
Tubes2* 6F2
2* 6U1
Output power2x65W RMS @ 4Ω
THD< 0.5% @ 60W RMS
Minimum speaker impedance4Ω
Total gain28dB
SNR75dB
Frequency response15Hz-20kHz (±1dB)
Input sensitivity1V
Channel separation58dB
Supported sampling rates (USB)PCM up to 32bit 192kHz
Tone control±6dB/oct @ 200Hz et 4000Hz
Supply voltage110V 60Hz
220V 50Hz
Standby consumption15W
Dimensions272*167*185mm
Weight6.08kg
Package1* Dayton Audio HTA100
1* Power cable
1* Bluetooth antenna
InputPhono
OutputSpeaker terminal
OutputSubwoofer
OutputJack 6.35mm
Channel2.1
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)65.0
3 reviews
Au top
Bonjour
Très bon rapport qualité prix sonne très bien avec mes enceintes Magnat monitor 220 de même que les vinyles a 1/4 de la puissance cela sonne déjà fort il y a de la réserve merci Audiophonic
 (3)
This review has been posted for DAYTON AUDIO HTA100 Hybrid Tube Class AB Amplifier Bluetooth 2x65W 4 Ohm
très bien
audiophonics et immanquablement le meilleur site audio toujours a l’écoute dont je remercie l'ensemble des personnes qui m'ont conseillé pour ce petit ampli dayton HTA100 agréable a regarder et à écouter pas encore rodé l’ensemble me convient suffisamment pour apprécier mes vinyles sur platine dp300f cellule Ortofon 2M Red MM plus câble enceinte van den hul cs122 enceinte bibliothèque highland 4301 et sub focal cub3 parfait pour mon bureau
 (3)
Un bon p'tit ampli !
Acquis il y a maintenant deux mois, je laisse un avis express sur ce HTA100.
J'en suis content : accompagné d'une paire d'Elipson et d'un petit subwoofer class D, ça sonne. Bien à volumes bas et moyen, sans distortion à fort niveau. Les deux vu-mètres analoqique aident bien à respecter la puissance de l'ampli en évitant de dépasser anormalement le 0/+3dB. Pratique. Bien pourvu en entrées diverses analogiques et numériques, il accepte mon iPad en USB permettant une lecturede qualité lossless.
De surcroit, il est compact, élégant et de bonne fabrication.
Un rapport qualité/prix excellent.
Merci à Audiophonics d'avoir importé ce petit ampli bien agréable.
 (3)
The perfect solution for enjoying the warmth of a tube amplifier, the Dayton Audio HTA100 features a hybrid design, combining modernity and...
