Class AB Amplifier 2x30W 4 Ohm
Dynavox proposed with the VT-60 a stereo amplifier in Class AB, capable of delivering a power of 2x30W at 4 Ohm. The VT-60 has a simple, sober and elegant design, and its proven design allows it to offer a beautiful sound reproduction: well placed bass and a large sound stage characterize this VT-60.
On the connector side, there are simply 4 stereo RCA inputs and a 3.5mm jack on the front panel, the latter allowing for example to connect a smartphone or a tablet. For its outputs, in addition to the classic speaker terminals, the VT-60 has a REC Out stereo RCA output for connecting recording devices.
Finally, there is a large volume control knob on the front panel, a source selector, as well as buttons to adjust bass, treble and balance levels.
Specifications | ||
Product type | Amplifier | |
Amplification type | Class AB | |
Power | 2x30W @ 4Ω | |
Frequency response | 10Hz - 30kHz (-3dB) | |
Impedance | 4-8Ω | |
Distortion | > 82dB (1W) < 0.07% (1kHz) | |
Input sensitivity | 110mV (30W) | |
Supply voltage | 230V 50Hz (power cable included) | |
Consumption | Max. 160W | |
Inputs | 4x Stereo RCA 1x Jack 3.5mm | |
Outputs | 1x Stereo RCA (REC Out) Speaker terminals | |
Dimensions | 430 x 70 x 284mm | |
Weight | 4.7kg |
Input | Jack 3.5mm |
Input | RCA |
Output | Speaker terminal |
Output | RCA |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 30.0 |
