With TPA3255 chip it's a really compact and perfect match to my needs. With tone control i can adjust the sound to fit my situation. Bought 12pcs to a exhibition.
The Fosi Audio BT20A PRO is a compact and powerful Class D amplifier, offered at a very resonable price.
For its connections, the BT20A PRO is simple and efficient, with stereo RCA or Bluetooth 5.0 input, and plated speaker terminals output as well as a 3.5mm jack pre-output.
On its front, the BT20A PRO has a tone control allowing you to adjust the level of bass and treble, in order to adapt the reproduction of the device to your audio system and your preferences. In addition, a bluetooth pairing history deletion function is now available by holding down the volume button for a long time.
A Bluetooth code may be requested to connect to the amplifier, it is "0000" or "1234".
Its amplification stage uses a high-end TI TPA3255 amplification chip, capable of developing a power of 225W under 4Ω per channel. All while providing clear and detailed sound reproduction.
The DIP8 format OP-AMP NE5532 chip is easily replaceable. This can allow you to get your favorite sound signature.
1 | Power indicator |
2 | Power switch |
3 | Treble control |
4 | Bass control |
5 | Volume control / Erasing Bluetooth pairing history |
6 | RCA Stereo input |
7 | Jack 3.5mm pre-out |
8 | Speaker terminal |
9 | Power plug |
10 | Bluetooth antenna |
Technical characteristic
Product type | Amplifier stereo |
Amplification type | Class D |
Input | 1x RCA stere'o Bluetooth 5.0 |
Output | Speaker terminal Pre-out jack 3.5mm |
Amplifier chip | TI TPA3255 |
Output power | 2x 225W / 4 Ohm @ 48V (1% THD) 2x 300W / 4 Ohm @ 48V (10% THD) 2x 110W / 4 Ohm @ 32V (1% THD) 2x 135W / 4 Ohm @ 32V (10% THD) |
Accepted impedances | 2-8Ω |
Frequency response | 20 Hz-20 kHz (± 1,2 dB) |
THD | 0.005% |
SNR | ≥ 108dB |
Bluetooth Codecs | ACC SBC |
Tone control | Bass / Treble with midpoint |
Power supply voltage | 24V-48V DC (AC adaptateur included) |
Dimensions (L*P*H) | 166x105x35mm |
Net Weight | 547g |
Color | Blue |
Package | 1x Fosi Audio BT20A PRO 1x Power supply 32V 5A |
Input | RCA |
Input | Bluetooth |
Output | Speaker terminal |
Color | Blue |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 225.0 |
Remote Control | No |
Average votes 4.8 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jan S.
Pascal M.
Philippe C.
Philippe C.
Philippe C.
