By buying this product you get 22 loyalty points
Amplifier TPA3251D2 MC8413 Bluetooth 5.0 24bit 192kHz 2x125W 4Ω
The Fosi Audio E10 Pro is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to develop a comfortable power of 2*125W under 4Ω with a high efficiency, a low distortion and a wide dynamic range, for a sound restitution as precise as musical. Moreover, the E10 Pro offers a complete range of connectors allowing it to adapt to most of the use scenarios. We find stereo RCA, Toslink optical, coaxial and a USB-A port for storage device, completed by a Bluetooth 5.0 reception capacity. Practical, the latter offers the possibility of broadcasting and controlling its music remotely easily from a smartphone or a tablet for example. On the output side, the amplifier offers of course speaker terminals but also a pre-out RCA output that can be used as a subwoofer output. The front of the E10 Pro also features a beautiful color screen.
1 | Power button |
2 | USB-A input |
3 | Previous track button |
4 | Play button |
5 | Nex track button |
6 | Input selection button |
7 | Volume button |
8 | Bluetooth antenna connector |
9 | Coaxial input |
10 | Optical Toslink input |
11 | RCA 1 input |
12 | RCA 2 input |
13 | RCA / Subwoofer output |
14 | Right channel speaker output |
15 | Left channel speaker output |
16 | Power supply input |
Product type | Amplifier |
Inputs | Bluetooth 5.0 2* Stereo RCA 1* USB-A (USB Host) 1* Optical Toslink 1* Coaxial |
Outputs | Speaker terminals 1* Steroe RCA / Subwoofer output |
Amplification chip | TPA3251D2 |
DAC chip | MS8413 |
Bluetooth chip | ATS2825 |
Output power | 2* 125W @ 4Ω, 1% THD |
Frequency response | 10Hz - 60kHz (±6dB) |
SNR | 92dB |
Dynamic range | 105dB |
THD | ≤ 0.01% |
Supported sampling rates (optical/coaxial) | PCM up to 24bit 192kHz |
Supply voltage | 220-250VAC (power cable included) |
Dimensions (W*D*H) | 460*400*170mm |
Color | Front panel : Silver Rest of the body : Black |
Package | 1* Fosi Audio E10 1* Power cable 1* Antenna 1* Remote controle 1* RCA cable |
Input | RCA |
Input | Optical |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Output | RCA |
Output | Subwoofer |
Output | Speaker terminal |
Color | Silver |
Color | Black |
Channel | 2.1 |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3251D2 |
Power (W) | 125.0 |
