FOSI AUDIO TB10D Class D Amplifier TPA3255 2x230W 4 Ohm
The Fosi Audio TB10D is a compact and powerful Class D amplifier, offered at a contained price. Its amplification stage uses a TI TPA3255 high performance chip, capable of developing a power of 2x230W under 4Ω with a high efficiency, all while providing a clear and detailed sound reproduction.
Reference : 17000
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 29-04-2025.
Fosi Audio TB10D
Amplificateur Class D 2x230W 4 Ohm
Fosi Audio TB10D Amplificateur Class D TPA3255 2x230W 4 Ohm
For its connectivity, the TB10D aims at simplicity and efficiency, with stereo RCA as input and speaker terminals as output.
On the front panel, the TB10D provides a tone control allowing to adjust the bass and treble levels, in order to adapt the restitution of the device to its listening and its audio system.
The 32V power supply provided allows the amplifier to develop a power of 2x110W under 4Ω (1% THD) or 2x60W under 8Ω (1% THD).
However, it accepts a power supply voltage of up to 48V. With such a power supply (sold separately), the TB10D is capable of delivering 2x230W under 4Ω (1% THD) or 2x130W under 8Ω (1% THD).
1ON/OFF LED
2ON/OFF Button
3Treble control
4Bass control
5Volume control
6Stereo RCA input
7Speaker output
8Power supply connector
Product typeAmplifier
Amplification typeClass D
Input1* Stereo RCA
OutputSpeaker terminals
Amplification chipTI TPA3255
Output power2*230W @ 4Ω, 48V, 1% THD
2*130W @ 8Ω, 48V, 1% THD
2*110W @ 4Ω, 32V, 1% THD
2*60W @ 8Ω, 32V, 1% THD
Frequency response20Hz-40kHz (±1dB)
THD≤ 0.3%
SNR≥ 90dB
Tone controlBass / Treble
Supply voltage18-48VDC (32V 5A power supply included)
Dimensions (L*P*H)105*142*40mm
Weight1.05kg
Package1* Fosi Audio TB10D
1* 32V 5A Power supply
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)230.0
Excellent for bass
Powerful. Does not care of your speaker impedance curve. Dynamic. If there is sudden peak, it stresses this over. Probably you have to pay 10 times more for getting better amplification for your woofer. I have compared this to mediocre 4x more expensive Yamaha, this blows it away with ease.
On higher range, above 1000 Hz not so good any more. Still with power and dynamics but somehow the sound is like it transforms sinus wave to square a little bit. Also, as tested shows some harmonics there. Could be excellent choice for old and lazy paper driver system. Gives you dynamics and sharpness without need for new drivers. In case you have some metallic tweeters then the combinations is not the best.
But still, for the money it is more than five stars. Would buy again.
This review has been posted for FOSI AUDIO TB10D Class D Amplifier TPA3255 2x230W 4 Ohm
The Fosi Audio TB10D is a compact and powerful Class D amplifier, offered at a contained price. Its amplification stage uses a TI TPA3255 high...
