FX-AUDIO XL-2.1BL Amplifier Bluetooth 4.0 TPA3116D2 2x 50W / 4 Ohm Black
FX-AUDIO XL-2.1BL Amplifier Bluetooth 4.0 TPA3116D2 2x 25W / 8 Ohm Black
4.5 / 5
Reference : 11401
64,90 €tax incl.
54,08 € tax excl.
Here is the FX-AUDIO XL-2.1BL, an audio amplifier TPA3116D2 complete with bluetooth, AUX jack 3.5mm, and especially a subwoofer output stereo delivering up to 100W under 8 Ohm.
It has 2 inputs on the rear: the first being the 3.5mm jack input, and the second one RCA stereo input. The 3rd way to use it is via bluetooth 4.0, to which it is enough to add the antenna provided (to be screwed behind).
Thismplifier with exceptional value for money is also equipped with numerous tone settings: bass, treble adjustment, accessible from the front of the device.
This littleamplifier in ultra-compact format will deliver unmatched sounds and performance for this price range.
Qobuz test of the amplifier 2.1 FX-AUDIO-XL 2.1, click on the image:
Fx audio XL2.1 BL
Operationpotentiometers and subwoofer channel:
  • The treeble knob adjusts the tone of the right and left channels.
  • The bass knob adjusts the output level of the subwoofer channel.
  • The SUB output is set to 180Hz.
Features:br>
  • Amplifier module TPA3116D2: 2x 50W at 4 Ohm / 2x 25W at 8 Ohm
  • Chips bluetooth CSR8635: Bluetooth 4.0
  • RUBYCON Capacitors
  • Subwoofer Output: 100W @ 8 Ohm
  • Signal to Noise Ratio (SNR): 86dB
  • Dynamic range: 98dB
  • Frequency response: 20Hz - 20kHz
  • Antenna bluetooth to screw
  • LED indicators on the front panel
  • Adjustment buttons: Bass / Treble / Volume
  • Inputs: AUX Jack 3.5mm / RCA Stereo
  • HP Stereo Outputs: On screwed terminal blocks supporting 4mm banana plugs
  • Bass releases: Stereo terminals
  • Power adapter included (24V / 4A)
  • Dimensions: 132x108x32mm
  • Weight: 500g
  • Color: black
Fx audio XL2.1 BL
InputJack 3.5mm
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)25.0
Remote ControlYes
11 reviews
Bien mais c'est du 2.1
Belle finition, tout petit, Bluetooth marche très bien mais ... c'est du 2.1 il faut absolument un caisson de basse séparé sinon il n'y a pas de grave dans les sorties enceintes normales. Je n'avais pas saisi cela sur la notice.
This review has been posted for FX-AUDIO XL-2.1BL Amplifier Bluetooth 4.0 TPA3116D2 2x 50W / 4 Ohm Black
Excellent !
Comme toujours, merci à M. David Aubert pour ses précieux conseils : cet ampli remplit toutes les cases de ce que je recherchais. Fonctionnalités, son, tout est bon dans ce petit (vraiment petit) appareil pour un rapport qualité/prix extraordinaire.
FX-AUDIO XL-2.1BL
rapport qualité prix exceptionnel (une caractéristique de la marque). Son très propre (trop?)varie suivant le support (ex pieds en sorbothane)...appareil très pratique et qui fait bien le job.
Bon petit ampli 2 voies+caisson
Résultats d'écoute très satisfaisant pour un système auxiliaire (bureau), la voie grave active est facile à régler, même si un réglage de la fréquence de coupure aurait été un plus. La liaison Bluetooth ne pose pas de problème particulier. Non testé en filaire, mais déjà en sans fil c'est plus que correct. Vu le tarif, il n'y a pas photo, le rapport qualité/prix est excellent. Bonne spatialisation, pas d'agressivité, très bonne restitution des détails. Utilisé avec un caisson passif très bas de gamme, et pourtant l'ensemble est très agréable à l'écoute. Livraison très rapide , parfait.
De la musique avant toute chose
La meilleure affaire de ma longue vie d'audiophile à petit budget.
