I.AM.D V200 WiFi FDA Digital Amplifier Blue OLED Class D TAS5614LA 2x65W / 8Ohm
Reference : 11039
184,90 €tax incl.
154,08 € tax excl.
Amplifier Class D TAS5614LA,I.AM.D V200Bintegrates a 24bit / 192kHz analog digital converter with an S / PDIF interface as standard. This amplifier has the characteristic of being " Full Digital", ie the S / PDIF signal is converted to I2S and then directly amplified by the TAS5614LA.
It has three digital inputs (USB, S / PDIF coaxial and Toslink optics). His OLED display displays in real time the source used as well as the sampling rate of the audio file being played.
This all-in-one amplifier proves to be the perfect companion for any digital source. Its compactness and ergonomics are assets sought after and added to its versatility.
This amplifier has a WiFi antenna allowing you to connect any compatible device (Smartphone, Computer, MAC, etc ...), and supports up to 24 bit / 44.1KHz.
All the technical characteristics of the TAS5614LAhere: TAS5614LA 150W Stereo / 300W Mono .
Test, trial of I.AM.D V200 pare Qobuz
Technical Specifications:
  • Amplifier Module TAS5614LA: 2x150W at 4 Ohm / 2x65W at 8 Ohm
  • USB interface CM6631A
  • Screen OLEDbacklit : Blue on black
  • WirelessWiFi / DLNA / AirPlay: supports up to 16 bit / 44.1KHz (CD quality)
  • Maximum distance from WiFi: 20 meters
  • Compatibilities: iOS 7 and higher / Android 4.2 and higher / MAC OS / Windows
  • Sampling rate display: Up to 24 bit / 192 kHz
  • Signal Noise Ratio (SNR):105dB
  • Piloting byinfrared remote control (Pressing the "Mute" button on the remote control allows you to use the Headphone output only)
Connectors:
  • Entries: S / PDIF OpticalToslink, Coaxial, USB-B, and 3.5mm Jack
  • Exits: HP screw terminals supporting 4mm banana plugs, and 3.5mm stereo headphones
  • WiFi antenna to be screwed on the back cover
Packaging:
  • Dimensions of the box: 185 x 112 x 35mm
  • Weight: 640 g
  • Black color
  • USB-A to USB-B cable, 8 feet round plastic, remote control, and power supply 24V 5A included
  • Instruction Manual (English)
[Img-17444-left-thickbox_default]
[Img-17446-left-thickbox_default]
[Img-17458-left-thickbox_default]
Channel2 (Stereo)
2 reviews
Superbe ampli
Superbe ampli !
Croyez le ou non cet ampli enterre un paquet d'amplis beaucoup plus cher, au moins 10 fois facilement.
Je l'ai utilisé en entrées numériques coaxial et optique avec une source CD et TV.
Il sonne relativement juste, un piano sonne comme un piano, un violon ressemble à un violon.
Au niveau spatialisation rien à dire, les instruments, les voix sont bien placés dans l'espace. Le niveau de détail est bon.
La dynamique est bonne, il y a du coffre, cet ampli peut driver des enceintes gourmandes sans problème.
S'il y a avait un reproche à faire, il manque un peu de matière, qui se matérialise par des aigus qui semblent maigrelets en harmonique, qui n'ont pas de volume dans l'espace. Et des basses pas assez profondes à mon gout.
En résumé la bande passante semble légèrement tronqué aux extrémités et il faudrait que les instruments soit 1/2 ton plus haut, enfin c'est mon avis très subjectif.
Mais si vous n'avez pas d'exigences très pointus comme sont ceux qui écoutent exclusivement de la musique classique au cordeau, je pense que l'on/je peut/x vivre avec sans problème.
Cerise sur le gâteau, cet ampli est écologique et prend peu de place.
Très bonne affaire à ce prix pour ceux qui veulent du bon son à bon prix.
This review has been posted for I.AM.D V200 WiFi FDA Digital Amplifier Blue OLED Class D TAS5614LA 2x65W / 8Ohm
Incroyable petite boîte
Incroyable mais vrai comment une si petite boîte peut elle marcher aussi bien.
Étonnant il enterre mon gros intégré AV thx bidule ultra machin etc...
Et il flirte avec mon ampli diy crescendo d'elektor mais seulement.
C'est transparent C'est spacieux en scène sonore et le grave est très bon peut-être une légère brillance dans le haut mais on lui pardonne. En plus il marche avec mon cd en coax du tonnerre et cerise sur gâteau marche parfaitement en USB avec un raspberry avec volumio, rune et moode audio.
Par contre une étoile en moins pour l'entrée analogique qui est comment dire poliment anecdotique.
Un ampli Fda c'est pour fonctionner en numérique directement, mais en début milieu de gamme le futur est à portée de main. À bon écouteur
