By buying this product you get 31 loyalty points
Pro Wireless Wall Mount Multiroom Stereo Amplifier 2X40W 8 Ohm
The iEast AMP-i50A WiFi Class D amplifier delivering 2x40W power is relevant in many aspects. It can perform high fidelity multiroom audio functions of WiFi and Bluetooth 4.0 wireless reception on any pair of stereo speakers.
Particularly suitable for multi-room installations with its integrated wall mounting, the AMP-i50A is perfectly adapted to any type of indoor integration, thanks to its infrared offset and its central RS232 serial port compatibility.
Dedicated iOS and Android applications offer the easiest way to set up a wireless sound system in any room of your home. The apps offer the option of synchronized playback, which allows you to stream music to all rooms at the same time by chaining multiple AMP-i50A's together.
You can stream your music from your smartphone, a tablet, a streaming application (Spotify, Qobuz, Deezer, Tidal...), a NAS or a USB storage device.
Equipped with an advanced Class D digital DSP, this 2x40W stereo amplifier produces a pleasant musical sound with low distortion and high current capacity.
Control is simple and intuitive from the dedicated iEast Play application, available free of charge for Android and iOS devices.
The AMP-i50A is compatible with many streaming services, allowing you to easily stream your music from any of them: Spotify, Qobuz, Deezer, Tidal, Tune In...
Product type | Amplifier |
Power | 2x5W @ 8Ω, 1kHz, 0.027% 2x32W @ 6Ω, 1kHz, 0.7% 2x40W @ 8Ω, 20Hz-20kHz, 5% |
Wireless connectivity | WiFi IEEE 802.11 b/g/n Bluetooth 4.0 |
Inputs | 1x RJ45 (10/100Mbps) 1x USB-A Host |
Outputs | Speaker terminals Serial port Jack 3.5mm to RS232 |
Streaming protocols | DLNA UPnP Airplay Spotify Connect Tune In QPlay |
Material compatibility | iOS Android iTunes for Mac and PC |
Streaming Services Compatibility | Spotify, Qobuz, Deezer, Tidal, Pandora, iHeartRadio, Rhapsody... |
NAS compatibility | DLNA |
Supported audio formats | MP3, WMA, AAC, AAC+, ALAC, FLAC, APE, WAV |
Speakers impedance | 4-32Ω |
Dynamic range | > 87dB |
SNR | > 88dB |
Stereo separation | > 81.5dB (1kHz) |
Frequency response | 20Hz - 20kHz (±3dB) |
Operating temperature | 0°C / 40°C |
Power supply | 24VDC 3.3A |
Dimensions | 112 x 225 x 31.5mm |
Weight | 1.3kg |
Package | 1x AMP-i50A 2x WiFi Antenna 1x IR blaster cable 1x IR remote control |
Input | Bluetooth |
Input | RJ45 |
Input | Micro SD |
Input | WiFi |
Output | Speaker terminal |
DAC / ADC Chip | NC |
Max sampling rate | NC |
Color | Black |
Amplifier chip | N/A |
