ORIGINAL AUDIO OPA-10 Class A Amplifier Bluetooth 5.0 2x70W 8 Ohm
Based on a proven and efficient architecture, the Original Audio OPA-10 Class A amplifier ensures a musical and dynamic sound reproduction. Its powerful amplifier circuit allows it to develop a power of 2x70W under 8Ω. Each channel of the amplifier embeds for that a 2SA1695 transistor and a 2SC4468 transistor.
By buying this product you get 39 loyalty points
Reference : 17396
399,00 €tax incl.
332,50 € tax excl.
Class A Amplifier Bluetooth 5.0 2x70W 8Ω
Original Audio OPA-10 Amplificateur Class A Bluetooth 5.0 2x70W 8Ω
Based on a proven and efficient architecture, the Original Audio OPA-10 Class A amplifier ensures a musical and dynamic sound reproduction. Its powerful amplifier circuit allows it to develop a power of 2x70W under 8Ω. Each channel of the amplifier embeds for that a 2SA1695 transistor and a 2SC4468 transistor. The input stage of the device integrates an OPA 5532 to provide a wide dynamic range and low distortion. The power supply stage of the OPA-10 is designed to provide a clean and perfectly stable electrical signal to the amplification circuit. At the base of this power supply, there is a toroidal transformer made of pure copper, perfectly isolated, as well as large filtering capacitors.
The connectivity of the OPA-10 is simple and efficient with stereo RCA and USB input. However, this connectivity is completed by a Bluetooth 5.0 receiver allowing you to broadcast your music remotely, for example from a smartphone or a tablet.
1Stereo RCA inputs
2USB-B input
3Bluetooth antenna
4Speaker terminals
5Power input
Product typeAmplifier
Amplification typeClass A
InputsBluetooth 5.0
1* USB-B
2* Stereo RCA
OutputsSpeaker terminals
Output power2x70W @ 8Ω
SNR> 90dB
Channel separation42dB (1kHz)
THD< 0.05% (1kHz, 8Ω, 1W)
Frequency response20Hz-20kHz (-3dB)
Input sensitivity0dB
Input impedance47kΩ
Supply voltage220VAC 50/60Hz
Dimensions248*248*70mm
Weight5.5kg
Package1* Original Audio OPA-10
1* Power cable
1* Bluetooth antenna
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)70.0
Based on a proven and efficient architecture, the Original Audio OPA-10 Class A amplifier ensures a musical and dynamic sound reproduction. Its...
