ORIGINAL AUDIO OPA-4A Tube Amplifier / Headphone Amplifier 12AU7 EL34-B Bluetooth aptX 2x6W 8 Ohm
The Original Audio OPA-4A is a high quality tube and headphone amplifier combo, based on the joint use of two 12AU7 tubes for the power stage and two EL34 tubes for the single-ended output stage within a linear circuit. The OPA-4A reveals a warm, smooth and musical sound, typical of tube designs, without losing its vigor.
By buying this product you get 84 loyalty points
Reference : 16338
849,00 €tax incl.
707,50 € tax excl.
Original Audio OPA-4A Amplificateur à Tubes Amplificateur Casque 12AU7 EL34-B Bluetooth aptX 2x6W 8 Ohm
The Original Audio OPA-4A is a high quality tube and headphone amplifier combo, based on the joint use of two 12AU7 tubes for the power stage and two EL34 tubes for the single-ended output stage within a linear circuit. The OPA-4A reveals a warm, smooth and musical sound, typical of tube designs, without losing its vigor. Its architecture allows it to develop a power of 2x6W under 8Ω for the speaker output and 2x4W under 32Ω for the balanced headphone output or 2x900mW under 32Ω for its single-ended headphone output. An ALPS 27 potentiometer allows a fine volume control of the sound level.
For its connectivity, the OPA-4A offers a balanced input on stereo XLR and single-ended on stereo RCA, as well as a Bluetooth connectivity. The latter allows you to broadcast your music remotely, from a smartphone for example. It also supports the aptX transmission codec, allowing to reach a quality of restitution close to that of the CD.
On the output side, there are speaker terminals at the back, but also a balanced headphone output in XLR 4-pole format and a single-ended headphone output on 6.35mm jack.
Product typeTube amplifier
Headphone amplifier
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Bluetooth
OutputsSpeaker terminals
1x Balanced 4 poles XLR headphone output
1x Single-ended Jack 6.35mm headphone output
Tubes2x 12AU7
2x AL34
Output power2x 6W (4-8Ω)
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL
Headphone amplifier powerBalanced output: 2x 4000mW @ 32Ω
Single-ended output : 2x900mW @ 32Ω
Frequency response20Hz ~ 50kHz (-1.5dB)
THD0.5% (1kHz)
SNR89dB
Input sensitivity350mV
Input impedance100kΩ
Channel balance< 0.5dB
Power supply220V 50Hz
Dimensions285 x 190 x 175mm
Weight13kg
Operating temperature0°C / +40°C
InputXLR
OutputSpeaker terminal
OutputJack 6.35mm
ClassClass A / AB
The Original Audio OPA-4A is a high quality tube and headphone amplifier combo, based on the joint use of two 12AU7 tubes for the power stage and...
