Pack DAYTON AUDIO WF40A Amplifier + DAYTON AUDIO B652 AIR Speakers + MEDIA-SUN SILHOUETTE MS2S Speaker Cable 4m
This ready-to-use package contains a Dayton Audio WF40A amplifier, a pair of Dayton Audio B652 speakers and a 4m Media-Sun MS2S speaker cable. An ideal pack to enjoy a system that is powerful, affordable, has many useful features and above all complete and therefore completely ready for use. All you have to do is plug in and enjoy your favourite songs.
By buying this product you get 20 loyalty points
Reference : 13094
209,00 €tax incl.
174,17 € tax excl.
Instead of 236,00 €
Pack content
Pack DAYTON AUDIO WF40A + DAYTON AUDIO B652 + MEDIA-SUN MS2S
Multiroom Amplifier WiFi 2x20W + Bookshelf Speaker Ribbon Tweeter+ Speaker Cable Copper / Silver
xDuoo XD-10 Amplificateur et DAC nomade XMOS AK4490 32bit 384kHz
Dayton Audio WF40A
WF40A Multiroom
A multiroom amplifier for the home
This small amplifier from Dayton Audio has WiFi connectivity and is extremely easy to set up. But more than its ease of use, the device also offers practical features such as multiroom, multi-channel and multi-user..:
Multiroom : The amp allows you to play your audio files synchronously in different rooms of your home, for smooth and transparent listening.
Multi-channels : It is also possible to listen to different music in each room by combining music with a defined device.
Multi-users : Finally, it also allows multiple users to control it to play multiple tracks in different rooms.
Intuitive control
The iEast mobile application allow you to control compatible devices, such as this WF40A, remotely over WiFi to enjoy the multi-room experience. So, this application allows you to stream your favorite music services, enjoy your music directly stored on your device or fetch files available on your computer or on a USB stick connected to the amplifier.
The configuration of the application is also very simple, since you just have to download it on the Play Store for Android or on the App Store for iOS then let yourself be guided by the instructions on the screen.
If the device is connected in Ethernet then it is not necessary to perform the configuration steps.
The WF40A also comes with an infrared remote control to control it directly from your sofa.
Dayton Audio WF40A télécommande
Dayton Audio B652
Dayton Audio B652
2 way ribbon tweeter speakers (The pair)
These 2-way speakers feature amazing dynamics, deep bass and surprising accuracy at the top of the spectrum thanks to a ribbon tweeter with foolproof efficiency. The 16.5cm diameter bass-midrange speaker allows a sound normally reserved for speakers of a larger size.
Media-Sun Silhouette MS2S
Speaker Cable Copper / Silver 2x2.5mm²
This Media-Sun Silhouette MS2S speaker cable provides very good electrical and mechanical properties. Made of 625 silver plated OFC copper wires per conductor, this one offers unequalled conductivity. It will therefore fit perfectly with the WF40A amplifier and the B652 speakers to ensure the cleanest reproduction.
Media-Sun MS2S
Dayton Audio WF40A
Output power2x20W RMS / 2x40W Max 8 Ohm
CompatibilityMac OS, iOS, Android, Windows
Supported protocolsDLNA
Airplay
WiFi801.11 b/g/n
Frequency response20Hz - 22kHz
SNR< 94.5dB
THD0.0005%
Crosstalk< 94.1dB
Supported file formats3AMP3, WMA, AAC, AAC+, Apple Lossless, FLAC, APE, WAV
Supported radio formatsStreaming MP3, CMA, AAC
Dayton Audio B562
Power40W RMS
Impedance6 Ohm
Frequency response70Hz - 25kHz
Sensitivity87dB
Dimensions300 x 180 x 163mm
Weight11kg
PackagingSold by the pair
Media-Sun MS2S
Length4m
Conductors materialCopper
Conductors platingSilver
Section2x2.5mm²
Section per strand0.004mm² (0.07mm diameter)
Cable thickness7x3mm
Sheath colorTransparent
FabricationGermany
InputRJ45
InputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Power (W)20.0
This ready-to-use package contains a Dayton Audio WF40A amplifier, a pair of Dayton Audio B652 speakers and a 4m Media-Sun MS2S speaker cable. An...
