SMSL AL200 Class D Amplifier Infineon MA5332MS XMOS XU316 Bluetooth 2x160W 4Ω 32bit 768kHz DSD256 MQA
SMSL with the AL200 unveils a powerful Class D amplifier, integrating quality components such as an Infineon MA5332MS amplifier chip. The AL200 is capable of delivering 2x160W at 4Ω and 2x80W at 8Ω. It also incorporates a third-generation XMOS XU316 USB interface, as well as an MQA and MQA-CD decoder.
4.6 / 5
By buying this product you get 25 loyalty points
Reference : 17865
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 17-04-2025.
SMSL AL200
SMSL AL200 Amplificateur Class D Infineon MA5332MS XMOS XU316 Bluetooth 2x160W 4Ω DSD256 MQA-CD
SMSL with the AL200 unveils a powerful Class D amplifier, integrating quality components such as an Infineon MA5332MS amplifier chip. The AL200 is capable of delivering 2x160W at 4Ω and 2x80W at 8Ω. It also incorporates a third-generation XMOS XU316 USB interface, as well as an MQA and MQA-CD decoder. It supports high sampling rates, up to PCM 32bit 768kHz and DSD256. Other features of the AL200 include a Bluetooth receiver chip, Jack 6.35mm TRS headphone output and 7 preset EQ. Compact and versatile thanks to its comprehensive connectivity, the SMSL AL200 amplifier will integrate easily into your HiFi system.
A powerful amplification chip
SMSL has turned to an Infineon MA5332MS Class D stereo amplifier chip for its AL200, ensuring excellent efficiency and low harmonic distortion. The AL200 delivers 2x160W of power at 4Ω or 2x80W at 8Ω, making it easy to drive a wide range of loudspeaker models.
XMOS XU316 USB interface & MQA decoder
The XMOS XU316 USB interface enables the AL200 to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD256. The AL200's USB-C input is therefore ideal for those wishing to transmit their music from a computer or smartphone in high quality. What's more, an MQA decoder makes it possible to enjoy these files and the MQA-CD format for sound as close as possible to the original studio recording.
Bluetooth 5.0 receiver
For added versatility, the AL200 is equipped with a Bluetooth 5.0 receiver, so you can control the amplifier and broadcast your music remotely from a smartphone or tablet, for example.
On the front of the AL200 is a Jack 6.35mm TRS headphone output connected to a high-performance CS43131 DAC/headphone amplifier chip. This means the AL200 can easily drive demanding headphones with impedances of up to 300Ω.
Please note that the volume control systems for the headphone output and the speaker output are totally isolated and separate. Adjusting the volume on one output will therefore not affect the other, and vice versa.
7 preset equalizers and tone control
The SMSL AL200 features 7 preset equalizers: Direct, Tone, SDB, Bass, Super Bass, Rock, Soft and Clear, as well as ±9dB tone control for bass and treble. This allows you to customize your sound according to your listening preferences and/or the type of music being played.
1Jack 6.35mm TRS headphone output
2Bluetooth antenna
3Screen
4Volume control
5Power input
6Right channel speaker output
7Left channel speaker output
8Optical Toslink input
9USB-C input
10Coaxial input
11Stereo RCA input
Product typeAmplifier
Amplification typeClass D
Inputs1* Stereo RCA
1* USB-C
1* Coaxial
1* Optical Toslink
1* Bluetooth
OutputsSpeaker terminals
1* Jack 6.35mm TRS headphone output
THD+N0.003%
SNR107dB
Channel separation98dB
Input sensitivity / Input impedance280mV / 22kΩ
Output power2x160W @ 4Ω
2x80W @ 8Ω
USB transmissionAsynchronous
USB compatibilityWindows 7/8/9/10/11
Mac OS
Linux
MQA / MQA-CD decoderUSB
Coaxial
Optical Toslink
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD256
Coaxial / Optical : PCM up to 24bit 192kHz, DSD64 (DoP)
Supply voltageAC 100-240V
Consumption40W
Dimensions (W*H*D)210*41*198mm
Weight1.78kg
Package1* SMSL AL200
1* Bluetooth antenna
1* Power cable
OutputSpeaker terminal
OutputJack 6.35mm
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)160.0
Remote ControlYes
5 reviews
Très bon amplificateur
Il remplit parfaitement le job, tout en délivrant une grosse puissance, pour un prix avantageux. Superbe !
This review has been posted for SMSL AL200 Class D Amplifier Infineon MA5332MS XMOS XU316 Bluetooth 2x160W 4Ω 32bit 768kHz DSD256 MQA
Mon Avis
Tres bon produit.
Utilisé pour la musique et le téléviseur, on a redécouvert un son de qualité.
INCROYABLE
Mettons de côté la question de la puissance brute, c est une claque monumentale ! Même à fort volume ce petit FDA pilote des grosses Dynaudio sans problème. La restitution est ultra détaillée, précise une neutralité quasi irréprochable. Un vrai pousse au crime, l’envie de monter le volume est omniprésente car l’écoute est vraiment très agréable et ce même à fort volume. L’image stéréo est vraiment convaincante, englobante mais je dois avouer que cette enthousiasme n’est rien face à une source full numérique. Streamez de la musique en 192 KHz depuis Qobuz via l’entrée optique et là on passe dans une tout autre dimension. Un peu de négatif tout de même… l’écran est nul, la navigation dans les options de l’ampli est de fait pas évidente... mais bon à ce prix ce serait dommage de s’en priver. Je pose ça là mais j’ai eu l’occasion de posséder des appareils bien plus onéreux et pourtant bien moins performants.
Très bon RQP
Les produits SMSL sont de haute qualité.
Cet ampli est installé dans l'environnement de mon PC pour alimenter deux enceintes passives pour des vidéoconférences. Son qualitatif avec la puce puce d'amplification Infineon MA5332MS. Je m'attendais à plus de puissance, le son en sortie de casque est bon mais est sans rapport avec celui produit par l'ampli casque SMSL C200.
SMSL AL200
Achete pour ses caracteristiques techniques de puissance et la presence de xmos , le smsl Al200 est un bon ampli avec pour une fois dans la marque toutes les entrees modernes, donc parfait pour brancher en usb un minipc multimedia et jouer les flacs.
Bien puissant et dynamique, a utiliser en tone direct.
Un seul regret, l'ampli ne se met pas en veille, on peut neanmoins eteindre l'ecran.
SMSL with the AL200 unveils a powerful Class D amplifier, integrating quality components such as an Infineon MA5332MS amplifier chip. The AL200 is...
