SMSL AO100 Class D Amplifier Infineon MA12070 Bluetooth 5.0 2x70W 4 Ohm
The SMSL AO100 is a small, powerful and affordable amplifier, whose careful design allows it to deliver a comfortable power and a precise and dynamic sound reproduction. An ideal ally for those who want to enjoy a HiFi audio system without breaking the bank.
Reference : 16554
139,00 €tax incl.
115,83 € tax excl.
SMSL AO100
SMSL AO100 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x70W 4Ω
Infineon MA12070
The Infineon MA12070 Class D amplifier chip used in the SMSL AO100 offers a high efficiency of 92% for a reduced power consumption level. The AO100 is thus able to develop a comfortable power of 2x70W under 4Ω, while offering a rich and dynamic sound reproduction.
Bluteooth 5.0 reception
With the SMSL AO100, no need to move to control the playback of your music. Integrating a Bluetooth 5.0 reception chip, it will allow you to broadcast your music at a distance, directly from your smartphone or tablet.
A high-performance power supply stage
The AO100 incorporates a high quality switching power supply. This provides a clean and stable electrical signal to the audio circuits.
Subwoofer output
Another feature of the AO100 is its pre-amplified subwoofer output. This will allow you to use an active subwoofer to create a true 2.1 immersive system.
1Display
2IR Receiver
3Multi-function button
4RCA input
5Bluetooth antenna
6Right channel speaker output
7Subwoofer output
8Left channel speaker output
9Power connector
Product typeAmplifier
Amplifier typeClass D
AmplificationInfineon MA12070
Output power2x70W @ 4Ω
InputsBluetooth 5.0
1x Stereo RCA
OutputsSubwoofer output (RCA)
Speaker terminals
Frequency response20Hz-40kHz
Bass/Treble adjustment-14dB ~ +14dB
THD+N0.004%
Channels separation109dB (1kHz)
Input sensitivity400mVrms
SNR104dB
Max input voltageLow gain: 2Vrms
High gain: 1.2Vrms
Supply voltage100-240VAC (Power cable included)
Consumption36W
Dimensions150 x 128 x 39mm
Weight560g
SMSL AO100 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x70W 4Ω SMSL AO100 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x70W 4Ω SMSL AO100 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x70W 4Ω SMSL AO100 Amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x70W 4Ω
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)70.0
Remote ControlYes
The SMSL AO100 is a small, powerful and affordable amplifier, whose careful design allows it to deliver a comfortable power and a precise and...
