TEMPO eA2 ICEPOWER Amplifier DAC ES9023 Bluetooth Silver 2x 25W / 8 Ohm
By buying this product you get 34 loyalty points
Reference : 9534
349,00 €tax incl.
290,83 € tax excl.
With a highly efficient onboard ES9023 converter, the TEMPO eA2 is a particularly gifted amplifier.
It incorporates an IcePower 50ASX2 amplifier module delivering 2x 45W under 4 Ohms and 2x 25W under 8 Ohms.
Versatile, it allows you to assign to it 3 sources (2 RCA and 1 line Jack 3.5mm).
Its iDevices-compatible Bluetooth function allows you to enjoy high quality audio sources remotely from your mobile devices or Mac after easy and intuitive pairing.
Its internal architecture as well as the choice of materials and finishes are all assets that make the TEMPO eA2 an amplifier that has nothing to envy the high-end competitors in its class.
Characteristics :
  • DAC ESS ES9023
  • Amplifier IcePower 50ASX2
  • Power consumption : 2x 25W under 8 Ohm, 2x 45W under 4 Ohm
  • Input Sensitivity: 400mV
  • Frequency response: 20Hz - 20kHz to -0.5dB
  • THD + D: 0.007%
  • Inputs: 2x stereo RCA, 3.5mm jack stereo line, Bluetooth compatible only iDevices
  • HP terminals output accepting banana plugs
  • Source Selection
  • Volume control
  • On / Off switch
  • Power consumption max. : 100W
  • Dimensions: 300x192x104mm
  • Weight: 2.2kg
  • Power cable, remote control and Bluetooth antenna included
