TOPPING PA7 Amplifier Class D Balanced 2x200W 4 Ohm Silver
The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of the PA7 provides effective transmission noise reduction.
Reference : 17644
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 19-12-2024.
Topping PA7
Topping PA7 Amplificateur Class D Symétrique 2x200W 4Ω Argent
Comparison between Topping PA7 and PA7 Plus
PA7
PA7 Plus
Output power
2*200W @ 4, THD+N < 1%
2*125W @ 8, THD+N < 1%
2*245W @ 4, THD+N < 1%
2*135W @ 8, THD+N < 1%
SNR
123dB
124dB
Dynamic range
123dB
124dB
Input sensitivity
Single-ended: 1.9Vrms
Balanced: 3.8Vrms
Single-ended: 2Vrms
Balanced: 4Vrms
Output level
83Vpp @ 4
89Vpp @ 8
90Vpp @ 4
91Vpp @ 8
Incredibly low distortion level
The PA7's performance in terms of distortion is close to that of a very good DAC. It always remains extremely low before clipping, ensuring a constant reproduction quality whatever the volume level.
Impressive power
The PA7, despite its compactness, is capable of delivering a significant power. It will indeed be able to deliver no less than 2x200W under 4Ω (1% THD+N) or 2x125W under 8Ω (1% THD+N). It is thus capable of powering greedy audio systems without difficulty while offering a beautiful dynamic.
Single-ended & balanced outputs
The Topping PA7 provides a double input connector. There is an XLR / Jack 6.35mm TRS combo for balanced transmission and a stereo RCA input for single-ended transmission.
Volume bypass
The Topping amplifier has a volume control. It is however possible to bypass this control to use the PA7 as a power amplifier, by associating an external preamplifier (not supplied).
12V Trigger
Equipped with a 12V trigger input, the PA7 can be connected to other devices to take advantage of an automatic on/off function of the system set up.
Product typeAmplifier
Amplification typeClass D
Inputs1* Balanced stereo XLR/TRS combo
1* Single-ended stereo RCA
OutputSpeaker outputs
Measurements
Single-endedBalanced
THD+N @ 1kHz (A-weighted)< 0.0005% @ 4Ω, 20W
< 0.0004% @ 8Ω, 20W
< 0.0004% @ 4Ω, 20W
< 0.0003% @ 8Ω, 20W
THD+N @ 20kBw (No-weighted)< 0.009% @ 4Ω, 20W
< 0.004% @ 8Ω, 20W
< 0.009% @ 4Ω, 20W
< 0.004% @ 8Ω, 20W
SNR @ Max out, 1kHz (A-weighted)123dB126dB
Dynamic range @ 1kHz (A-weighted)123dB126dB
Frequency response20Hz-40kHz (±1.5dB)20Hz-40kHz (±0.3dB)
Output level83Vpp @ 4Ω
89Vpp @ 8Ω
83Vpp @ 4Ω
89Vpp @ 8Ω
Noise (A-weighted)< 17µVrms< 17µVrms
Crosstalk @ 1kHz-96dB-116dB
Input sensitivity1.9Vrms3.8Vrms
Gain25.7dB19.8dB
Channel balance0.5dB0.5dB
Output power2*210W @ 4Ω, THD+N < 10%
2*150W @ 8Ω, THD+N < 10%
2*200W @ 4Ω, THD+N < 1%
2*125W @ 8Ω, THD+N < 1%
Load impedance4-8Ω
Dimensions (L*P*H)200*155*41mm
ColorSilver
Package1* Topping PA7
1* Supply voltage
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipN/A
Power (W)200.0
The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is...
