By buying this product you get 119 loyalty points
With the R-N800A, Yamaha offers a versatile, high-performance connected amplifier with both analog and digital inputs. The R-N800A also features high-quality components and optimized circuitry for accurate and musical sound reproduction.
The R-N800A is based on the brand's ToP-ART (Total Purity Audio Reproduction Technology), ensuring optimal processing and transmission of the input signal, which remains low in noise and distortion. This particular architecture is based on a balanced design. It is also associated with the ART (Anti-Resonance and Tough) technology, promoting a better damping and a greater rigidity of the chassis. This design allows the R-N800A to offer a sound reproduction of a beautiful richness.
Equipped with an ESS ES 9080Q 32bit 384kHz DAC, the R-N800A offers great performance in terms of signal to noise ratio. This connected amplifier also exploits all the advantages of high-resolution audio sources thanks to its exclusive Yamaha network module. Yamaha's goal here with the R-N800A is to reproduce the subtle ambience of concert halls with a level of nuance and detail pushed to the extreme.
To eliminate power loss and audio signal degradation, the R-N800A is equipped with large grounding cables. This is one of the features that make it a high-end product. For the amplifier section, a screw connection has been adopted to strengthen the grounding. The result is a very clear sound.
The R-N800A's Pure Direct mode allows the audio signal to bypass all tone and balance control circuits. This ensures better sound quality while preserving the power of the amplifier. A method that allows for a transparent and musical reproduction.
The R-N800A's front-panel Loudness function allows you to adjust the balance of high and low frequencies while preserving a full tonal range regardless of the volume level. This can be a useful tool for dealing with the natural loss of high and low frequencies at low sound levels.
The R-N800A is both an amplifier and a network player, and features Yamaha's MusicCast system, which allows it to be compatible with many streaming services such as Spotify, Deezer, Tidal, and Qobuz. So you can access all your music quickly and easily via your smartphone. The Yamaha amplifier is also compatible with AirPlay 2. So you can also stream your music via Apple Music.
This amplifier supports the majority of audio sources, allowing you to enjoy superior sound in many different usage scenarios.
1 | RCA CD input |
2 | 2x Optical inputs |
3 | 2x Coaxial inputs |
4 | USB-B port |
5 | Ethernet plug (RJ45) |
6 | WiFi / Bluetooth antenna |
7 | Service port (update) |
8 | AC power plug |
9 | 2x Line out (RCA) |
10 | Phono input (RCA) / GND |
11 | Pre-out (RCA) |
12 | Radio antenna connector |
13 | Trigger output |
14 | Subwoofer output |
15 | Speaker terminals |
With the phono input of the R_N800A you can easily enjoy your turntable and your record collection.
Native DSD256 and PCM 384kHz playback are also supported, allowing you to enjoy exceptional sound quality, making full use of high-resolution audio sources.
You can store up to 40 DAB/DAB+ radio stations.
Product type | Connected amplifier |
Network section | Supported file formats: MP3, WMA, MPEG-4 AAC, WAV, FLAC, AIFF, DSD AirPlay: Yes |
Dynamic power output | 2x 140W @ 8Ω 2x 170W @ 6Ω 2x 220W @ 4Ω 2x 290W @ 2Ω |
Rated power output | 2x 100W @ 8Ω 2x 120W @ 6Ω |
Frequency response | 10Hz-100kHz 0±1.0dB 20-20kH 0±0.5dB (Pure Direct) |
Inputs | 1* Phono RCA 3* Stereo RCA 2* Optical Toslink 2* Coaxial 1* USB-B 1* RJ45 WiFi Bluetooth |
Outputs | Speaker terminals 1* Stereo RCA pre-out 1* Subwoofer RCA output 1* Jack 6.35mm headphone output |
Trigger output | |
FM 50dB sensitivity (IHF, 1 kHz, 100 %mod., mono) | 3µV (20.8dBf) |
SNR FM | Mono : 69dB Stereo: 68dB |
Pure Direct feature | |
ToP-ART |
Standby consumption | 0.1W |
Dimensions | 435*151*395mm |
Weight | 11.4kg |
Color | Black |
Input | RCA |
Input | Optical |
Input | RJ45 |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | WiFi |
Output | Subwoofer |
Output | RCA |
Output | Jack 6.35mm |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | ES9080Q |
Power (W) | 220.0 |
Remote Control | Yes |
