3E AUDIO A7 MONO Amplifier
3E Audio, a recognized player in the DIY world, now offers a Class D mono amplifier incorporating audiophile Hi-Fi components. The A7 Mono amplifier is based on one TI TPA3255 chips in PBTL configuration, and a dual OPA1656. This means it can deliver up to 1x 260W into 4 ohm power.
4.5 / 5
By buying this product you get 23 loyalty points
Reference : 20377
239,00 €tax incl.
199,17 € tax excl.
Shipping date: 29-04-2025.
3E Audio A7 MonoClass D Mono Amplifier PBTL 1xTPA3255 1x260W 4 ohm
Photo of 3E Audio A7 Mono
In terms of connectors, the 3E Audio A7 mono features an RCA input, a practical balanced XLR/Jack 6.35mm combo input, and an output on speaker terminals. The RCA input gain can be adjusted (LOW=26dB, HIGH=29dB), and the preamplifier stage and volume control can be bypassed for use as a power amplifier. Versatile and high-performance, this little amplifier is able to offer a good reserve of power while preserving the final sound reproduction.
A7
A7se
A7 Mono
A5se
A5
Amplification chip
2x TPA3255
2ch - PBTL
1x TPA3255
2ch - BTL
1x TPA3255
1ch - PBTL
1x TPA3251
2ch - BTL
2x TPA3251
2ch - PBTL
Output power
(4 ohm, THD+N=1%)
2x 250W
2x 230W
1x 260W
2x 140W
2x 150W
Output power
(8 ohm, THD+N=1%)
2x 140W
2x 130
1x 150
2x 70W
2x 80W
Load impedance
2-16 ohm
4-16 ohm
2-16 ohm
4-16 ohm
2-16 ohm
3E Audio A7 Mono: TPA3255 chip
The TPA3255 amplifier chips offer a consistent level of output power, as the 3E Audio A7 mono delivers up to 1x 260W into 4 ohm and up to 1x 150W into 8 ohm (THD+N = 1%). In addition, the PBTL configuration maintains continuous, stable output power while reducing power losses. It also enables the amplifier to withstand loads of up to 2 ohms.
TPA3255 chips
Interchangeable DIP8 OPAs
3E Audio A7 Mono: Interchangeable OPA
The preamplifier stage of the 3E Audio A7 Mono is made up of a dual OPA1656 OPAs mounted in DIP 8 and easily replaceable with pliers, thanks to the design of the case. In fact, the OPAs can be accessed through two hatches without opening the case. Here's a non-exhaustive list of compatible OPAs: OPA1656, OPA1602, OPA2134, NE5532P, LME49720, LM4562, MUSES02, MUSES8920, NJM4580, NJM4556, NJM2068, OP249, AD827, etc.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling by the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty. Please refer to the manual to carry out the operation.
3E Audio A7 Mono: Quality components
Rubycon 63V 1000uF capacitors
Rubycon capacitors meet high current requirements, reducing noise and improving THD.
Flat wire coils
Flat-wire coils
The coils used in the amplifier provide improved linearity and reduced distortion, while delivering the best performance whatever the load.
TDK capacitors
TDK capacitors
These highly reliable LC filter capacitors ensure optimum audio performance.
3E AUDIO A7 Mono amplifier PCB photo
3E Audio A7 Mono overview
Overview of the 3E Audio A7 Mono
1Left channel status LED
2RCA input status LED
3Multifunction button
4XLR input status LED
5Right channel status LED
6Balanced XLR/Jack 6.35mm combo input
7RCA input
8RCA gain control
9Speaker terminal output
10Volume bypass
1138V-52V DC power supply via DC jack
Test du 3E Audio A7/A7 Mono test by Audio Science Review
"If my memory serves me right, 3e audio was the first company to bring us high performance TI TPA3255 class D amplifiers with PFFB. While they have more competition now, it is clear they intend to stay on top of this game, squeezing every bit of performance out of this architecture, while providing nice feature set. We are talking high performance, high power amplifiers that are tiny yet deliver what people need in most cases. I am happy to recommend 3e audio A7 / A7 Mono stereo audio amplifiers."
Product typeClass D amplifier
ChannelsMono
Amplification chip1x TI TPA3255
OPADual OPA OPA1656
StructurePFFB
Inputs1x Single-ended RCA input
1x Balanced XLR/jack 6.35mm combo input
Output1x Speaker terminal output
Input impedanceRCA : 10KΩ
XLR/TRS : 20KΩ
Volume attenuation-50dB
Volume bypass
RCA gain control
Audio specifications (RCA IN)
THD+N (5W)0.0007% @ 4Ω
0.0006% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)123dB
Dynamic range (1% THD+N, 1KHz, A-wt)123dB
Frequency response (±0.5dB)20Hz-30KHz
Noise (A-wt)< 20uVrms
Crosstalk-120dB
Gain26dB / 29dB
Input sentivity1.75Vrms
Output power (1% THD+N)1x 480W @ 2Ω
1x 260W @ 4Ω
1x 150W @ 8Ω
Output power (10% THD+N)1x 600W @ 2Ω
1x 320W @ 4Ω
1x 200W @ 8Ω
Output impedance2Ω-16Ω
audio Specification (XLR IN)
THD+N (5W)0.0006% @ 4Ω
0.0005% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)126dB
Dynamic range (1% THD+N, 1KHz, A-wt)126dB
Frequency response (±0.5dB)20Hz-35KHz
Noise (A-wt)< 15uVrms
Crosstalk-130dB
Gain20dB
Input sensitivity3.5Vrms
1x 260W @ 4Ω
1x 150W @ 8Ω
1x 320W @ 4Ω
1x 200W @ 8Ω
Power supply38V-52V DC 5A/9A (The supplied power supply operates on 110V and 230V)
Power consumptionOFF: < 0.4W
ON (no audio): 6W
Dimensions170 x 168 x 46mm
Weight1000g
Package1x 3E Audio A7 Mono amplifier
1x 48V 10A mains adapter
InputJack 6.35mm
InputXLR
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipTPA3255
Power (W)260.0
2 reviews
A7 mono
Superbe ampli, je les préfères à mes anciens fosi v3 mono. Livraison rapide au Canada. Avec le support de 3e audio j’ai réussi à régler le problème du auto-standby trop sensible. Maintenant c’est parfait.
This review has been posted for 3E AUDIO A7 MONO Class D Mono Amplifier PBTL 1xTPA3255 1x260W 4 Ohm
Very highly recommended (with a small caveat)
This is definitely a one-of-a-kind class D amplifier
Stays cool (unlike other PFFB amplifiers), superb sound quality (check out the measurements on audiosciencereview and archimago's site)
The reason for the 4 stars is that it has an auto-standby feature that cannot be adjusted or switched off. This is really annoying and for me this is a bug, not a feature
3E Audio, a recognized player in the DIY world, now offers a Class D mono amplifier incorporating audiophile Hi-Fi components. The A7 Mono...
