3E AUDIO A7 Amplifier
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier is based on two TI TPA3255 chips in PBTL configuration, and two dual OPA1612A OPAs. This means it can deliver up to 2x 250W into 4 ohm power.
4.0 / 5
By buying this product you get 37 loyalty points
Reference : 20372
379,00 €tax incl.
315,83 € tax excl.
3E Audio A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 ohm
Photo of 3E Audio A7
In terms of connectors, the 3E Audio A7 features an RCA input, a practical balanced XLR/Jack 6.35mm combo input, and an output on speaker terminals. The RCA inputg gain can be adjusted (LOW=25dB, HIGH=28.5dB), and the preamplifier stage and volume control can be bypassed for use as a power amplifier. Versatile and high-performance, this little amplifier is able to offer a good reserve of power while preserving the final sound reproduction.
A7
A7se
A7 Mono
A5se
A5
Amplification chip
2x TPA3255
2ch - PBTL
1x TPA3255
2ch - BTL
1x TPA3255
1ch - PBTL
1x TPA3251
2ch - BTL
2x TPA3251
2ch - PBTL
Output power
(4 ohm, THD+N=1%)
2x 250W
2x 230W
1x 260W
2x 140W
2x 150W
Output power
(8 ohm, THD+N=1%)
2x 140W
2x 130
1x 150
2x 70W
2x 80W
Load impedance
2-16 ohm
4-16 ohm
2-16 ohm
4-16 ohm
2-16 ohm
3E Audio A7: Two TPA3255 chips
The two TPA3255 amplifier chips offer a consistent level of output power, as the 3E Audio A7 delivers up to 2x250W into 4 ohm and up to 2x140W into 8 ohm (THD+N = 1%). In addition, the PBTL configuration maintains continuous, stable output power while reducing power losses. It also enables the amplifier to withstand loads of up to 2 ohms.
TPA3255 chips
Interchangeable DIP8 OPAs
3E Audio A7: Interchangeable OPAs
The preamplifier stage of the 3E Audio A7 is made up of two double OPA1612A OPAs mounted in DIP 8 and easily replaceable with pliers, thanks to the design of the case. In fact, the OPAs can be accessed through two hatches without opening the case. Here's a non-exhaustive list of compatible OPAs: OPA1656, OPA1602, OPA2134, NE5532P, LME49720, LM4562, MUSES02, MUSES8920, NJM4580, NJM4556, NJM2068, OP249, AD827, etc.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling by the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty. Please refer to the manual to carry out the operation.
3E Audio A7: Quality components
Elna Silmic II
Elna Silmic II
ELNA Silmic II capacitors have proven capacities and are often used in Hi-Fi applications.
Rubycon 63V 1000uF capacitors
Rubycon capacitors meet high current requirements, reducing noise and improving THD.
Flat wire coils
Flat-wire coils
The coils used in the amplifier provide improved linearity and reduced distortion, while delivering the best performance whatever the load.
TDK capacitors
TDK capacitors
These highly reliable LC filter capacitors ensure optimum audio performance.
3E AUDIO A7 amplifier PCB photo
3E Audio A7 overview
Overview of the 3E Audio A7
1Left channel status LED
2RCA input status LED
3Multifunction button
4XLR input status LED
5Right channel status LED
6Balanced XLR/Jack 6.35mm combo input
7RCA input
8RCA gain control
9Speaker terminal output
10Volulme bypass
1138V-48V DC power supply via DC jack
Product typeClass D amplifier
ChannelsStereo
Amplification chip2x TI TPA3255
OPADual OPA OPA1612A
StructurePFFB
Inputs1x Single-ended RCA input
1x Balanced XLR/jack 6.35mm combo input
Output1x Speaker terminal output
Input impedanceRCA : 10KΩ
XLR/TRS : 20KΩ
Volume attenuation-50dB
Volume bypass
RCA gain control
Audio specifications (RCA IN)
THD+N (5W)0.0007% @ 4Ω
0.0006% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)123dB
Dynamic range (1% THD+N, 1KHz, A-wt)123dB
Frequency response (±0.5dB)20Hz-35KHz
Noise (A-wt)< 20uVrms
Crosstalk-100dB
Gain26dB / 29dB
Input sentivity1.75Vrms
Output power (1% THD+N)2x 250W @ 4Ω
2x 140W @ 8Ω
Output power (10% THD+N)2x 300W @ 4Ω
2x 180W @ 8Ω
Output impedance2Ω-16Ω
audio specifications (XLR IN)
THD+N (5W)0.0006% @ 4Ω
0.0005% @ 8Ω
SNR (1% THD+N, 1kHz, A-wt)126dB
Dynamic range (1% THD+N, 1KHz, A-wt)126dB
Noise (A-wt)< 15uVrms
Crosstalk-110dB
Gain20dB
Input sensitivity3.5Vrms
2x 140W @ 8Ω
2x 180W @ 8Ω
Power supply38V-48V DC 5A/10A
Power consumptionOFF: < 0.4W
ON (no audio): 9W
Dimensions170 x 168 x 46mm
Weight1000g
Package1x 3E Audio A7 amplifier
1x 48V 10A mains adapter
InputJack 6.35mm
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)250.0
Excellent ampli !
Commandé un jeudi, reçu le lundi suivant, nickel ! Ce petit ampli est un vrai bijou de puissance et de contrôle des enceintes qu'il alimente. Si en plus il est fiable (on verra à l'usage, je ne l'ai installé qu'hier !), alors mon setup audio ne va plus bouger pendant un bon moment ! Seuls bémols:
1- l'ampli a été livré avec un cordon secteur pas adapté au bloc d'alim (2 broches au lieu de 3), j'ai dû prendre un cordon secteur avec la terre qui trainait dans un tiroir...
2- l'ampli est équipé d'un système d'auto-off/on avec des valeurs seuils discutables: en écoute à faible niveau, l'ampli s'éteint tout seul au bout de 5 min comme s'il ne recevait aucun signal, dommage pour une utilisation comme ampli de puissance avec bypass du contrôle de volume du A7. Pour contourner le problème, il faut atténuer en baissant le potard de volume de l'ampli, et augmenter le niveau de sortie du pré-ampli qui est avant.
Moyennant cela, l'ampli est génial et super bien adapté pour driver des enceintes de faibles impédances.
This review has been posted for 3E AUDIO A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 Ohm
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier...
