AIYIMA A08 PRO Class D Amplifier TPA3255 2x220W 4 Ohm Bluetooth 5.0 Aptx-HD LDAC
The Aiyima A08 PRO is a small, very powerful, high performance and affordable Class D amplifier. It is based on a TPA3255 amplifier chip and a NE5532P PDO, allowing it to deliver 2x220W of power into 4Ω.
4.7 / 5
Reference : 16737
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 16-04-2025.
Aiyima A08 pro
Class D Amplifier TPA3255 2x220W 4Ω
Aiyima A08 pro Amplificateur Class D
The Aiyima A08 PRO is a small, very powerful, high-performance and affordable Class D amplifier. It is based on a TPA3255 amplifier chip and a NE5532P PDO, allowing it to deliver 2x220W of power into 4Ω, with a rich and dynamic sound reproduction. The front of the unit features a nice meter showing the output voltage on the speaker terminals, 2 bass / treble controls, as well as a large volume control. On the back there is a stereo RCA input, a Bluetooth antenna, as well as the speaker terminals and a 3.5mm jack line output for active speakers or subwoofers.
The design of the A08 PRO is also designed to match perfectly with the Aiyima T8 tube preamplifier, the latter is placed directly in the notch on the top of the case.
The Aiyima T8 preamplifier is sold separately.
Technical
Type of productAmplifier
Type of amplifierClass D
Amplification chipTPA3255
OPANE5532P
Bluetooth chipQCC5125
Protocoles Bluetooth 5.0SBC / AAC / Apt-X / Apt-X HD / LDAC
Inputs1x Stereo RCA
1x Bluetooth
OuputsSpeaker terminals
1x 3.5mm line level jack
Power2x220W / 4 Ohm (@48V at 1% THD+N)
2x280W / 4 Ohm (@48V at 10% THD+N)
2x130W / 4 Ohm (@36V at 1% THD+N)
2x170W / 4 Ohm (@36V at 10% THD+N)
Compatible speaker impedances4-8Ω
SNR≥ 104dB
Input sensitivity0.775V
Frequency response20Hz-20kHz (±1dB)
Power supply voltage24-48VDC (36V 6A power supply included)
Dimensions152x123x40mm
ColorNoir
Net weight700g
OutputSpeaker terminal
OutputJack 3.5mm
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)220.0
6 reviews
Dommage
Ampli bon son avec très bonne dynamique.
Problèmes : écartement bornes hp pas normalisées.
diamètre passages de câbles hp très petits.
Bouton power on / off capricieux.
Ampli reçu pas neuf, modèle d'expo ?
This review has been posted for AIYIMA A08 PRO Class D Amplifier TPA3255 2x220W 4 Ohm Bluetooth 5.0 Aptx-HD LDAC
Dommage
très bon ampli neutre et très bonne dynamique .
Les problèmes : espacement des bornes hp pas normalisées .
le diamètre de passage câble hp très petit.
bouton marche arrêt capricieux
Le produit que j'ai reçu n’était pas neuf , modèle d'expo ?
excellent rapport qualité prix
tres satisfait du son et de la puissance .
très bon; recommandable
J'ai eu en petit format des ampli intégrés smsl ; fx audio et audiophonics acquis sur ce même site . Ce aiyima est meilleur que ce cités précédemment . Son très naturel et détaillé ; très bonne spatialisation ; les correcteurs grave et aigu sont très juste et quelle transparence ! Impression d'écouter un ampli beaucoup plus cher . A ce prix difficile de faire mieux .
Aiyima A08 Pro
Very good sound and look. Very good packed and fast delivery.
The Aiyima A08 PRO is a small, very powerful, high performance and affordable Class D amplifier. It is based on a TPA3255 amplifier chip and a...
