AIYIMA A200 Class D Amplifier TPA3255 2x180W 4 Ohm Bluetooth 5.0 Aptx-HD
The Aiyima A200 is a powerful and affordable Class D stereo amplifier. It is based on a TPA3255 amplifier chip and a NE5532 AOP.
Reference : 16826
139,00 €tax incl.
115,83 € tax excl.
Aiyima A200
Stereo Amplifier TPA3255 2x180W 4Ω
Aiyima A200 Amplificateur Class D
The Aiyima A200 is a powerful and affordable Class D stereo amplifier. It relies on a TPA3255 amplifier chip and a NE5532 PDO, allowing it to deliver up to 2x200W of power at 4Ω. The front panel features a large volume / source selection knob, as well as the ON / OFF button. On the back there is a stereo RCA input, a Bluetooth antenna, a USB-B input and speaker terminals for passive speakers.
The USB input and the Bluetooth input use the same module. If the 2 sources are active, priority is given to Bluetooth.
Technical specifications
SpEcifications
Type of productAmplifer
Type of amplifierClass D
Amplification chipTPA3255
OPANE5532
Bluetooth chipQCC3034 (Bluetooth 5.0)
Protocoles BluetoothSBC / AAC / Apt-X / Apt-X HD
Inputs1x Stereo RCA
1x Bluetooth
1x USB-B
OutputsSpeaker terminals
power2x180W / 4 Ohm (1% THD+N)
2x200W / 4 Ohm (10% THD+N)
Compatible speaker impedances4-8Ω
SNR≥ 95dB
Frequency response20Hz-20kHz (±3dB)
Power supply voltage110 - 220V AC (Power cable included)
Dimensions173x120x120mm
Net weight1.6kg
Input
  • Bluetooth
  • RCA
  • USB
Output
  • Speaker terminal
Color
  • Black
Channel
  • 2 (Stereo)
Class
  • Class D / T
Amplifier chip
  • TPA3255
Power (W)
  • 180.0
Remote Control
  • No
2 reviews
Oh My God !
Eh bien, c'est très bien... Il ne fonctionne qu'avec le Bluetooth, car c'est juste pour moi un ampli d'appoint... Mais il marche vraiment très bien, très étonné par la droiture, la puissance, le détail et la tenue des graves... Pour le prix, c'est un sans-faute, à découvrir. Grand merci à Audiophonics pour la livraison bien protégée...
This review has been posted for AIYIMA A200 Class D Amplifier TPA3255 2x180W 4 Ohm Bluetooth 5.0 Aptx-HD
vers le Graal
Permettez-moi l’expression « je suis sur le cul » pour le prix et son poids, c’est 1,6 kg de précision et de puissance.
Cela fait un peu plus d’un mois qu’il excite mes Resound RS215 et jamais auparavant je n’avais écouté un ampli qui reproduisait une telle richesse de timbres et ce dans tout le spectre audible, les voix sont charnues et avec beaucoup de charme, les basses sont percutantes et d’une tenue exemplaire, les aigus d’une finesse redoutable, bref, what else !
Je redécouvre ma bibliothèque musicale, il délivre les informations avec une justesse chirurgicale.
Il lui manque juste une télécommande pour ressembler au Graal.
Je peux en conclure, en fonction de mes goûts « audiophile », que cette petite boîte est un instrument de musique à part entière.
