AIYIMA T9 Amplifier TPA3250 Tubes 2x 6K4 Bluetooth 5.0 2x60W 4 Ohm
The Aiyima T9 is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank and without multiplying the number of devices. Its amplifier stage uses a TPA3250 chip associated with two 6K4 tubes, allowing it to develop a power of 2x60W under 4Ω with the supplied 24VDC power supply or 2x95W under 4Ω with a 30VDC power supply.
3.0 / 5
Reference : 17339
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 29-04-2025.
Aiyima T9
Aiyima T9 Amplificateur TPA3250 2x 6K4 Bluetooth aptX HD 2*60W 4Ω
The Aiyima T9 is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank and without multiplying the number of devices. Its amplifier stage uses a TPA3250 chip associated with two 6K4 tubes, allowing it to develop a power of 2x60W under 4Ω with the supplied 24VDC power supply or 2x95W under 4Ω with a 30VDC power supply (sold separately). It thus offers a round and musical sound of the most beautiful effect. Moreover, two potentiometers allow an adjustment of the bass and treble to adapt the restitution of the T9 to your listening and your audio system. However, the great strength of the T9 probably lies in its great versatility, which it owes to its complete connectivity. Indeed, we find in input USB-B, Toslink optical, coaxial, stereo RCA but also a wireless Bluetooth 5.0 connectivity, allowing the diffusion of its music from a smartphone for example.
Replaceable tubes: 6J1, 6J2, GE5654, 6J3, 6J4, 6J5, 6Ж1п, 6AK5, etc.
Product typeAmplifier
Amplification chipTPA3250
Tubes2* 6K4
InputsBluetooth 5.0
1* Stereo RCA
1* USB-B
1* Optical Toslink
1* Coaxial
OutputsSpeaker terminals
1* Jack 3.5mm
Output power2*60W @ 4Ω, 24V, 1% THD
2*30 @ 8Ω, 24V, 1% THD
2*95 @ 4Ω, 32V, 1% THD
2*50W @ 8Ω, 32V, 1% THD
Bluetooth chipAC6926C
USB interfaceCM6542
OPANE5532
THD0.07%
SNR≥ 98dB
Frequency response20Hz-20kHz (±1dB)
Bass/Treble adjustment±6dB
Supply voltage18-30VDC 3A (Power supply included)
Package1x AIYIMA T9
1x Remote control
1x 24V power adapter
Dimensions115*98*54mm
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3250
Power (W)60.0
Remote ControlYes
2 reviews
perplexité et mise en garde
Une seule étoile car j'y entends plus d'inconvénients que de plaisir, même à ce petit prix.
D'abord, le plus gênant, c'est ce volume sonore quasi incontrôlable à l'écoute de la plupart de mes CDs et flac, mes 2 principales sources de musique. Aiyima me dit qu'il n'y a pas de mise à jour possible sur le fait que l'avant-dernier cran du volume sonore reste trop élevé. Un cran de plus, et le son est coupé. La seule façon d'y remédier est de passer par l'ordinateur, où il faut y baisser le son interne pour pouvoir ensuite contrôler celui du T9, dommage. Ce "détournement" permet quand même de profiter des radios internet via l'ordi ou de Youtube par exemple.
Autre inconvénient, ce clic intermittent et récurrent dès qu'on laisse en veille le T9, qui signale sa mise en pause. Il est léger mais vraiment pas indispensable.
Enfin, il faut absolument changer les tubes et utiliser un DAC externe pour obtenir un son plus acceptable. Malgré cela, la stéréo reste simplement confinée dans les enceintes, sans réelle scène sonore.
Bref, je ne le recommande qu'à certaines conditions d'utilisation et d'exigence musicale.
This review has been posted for AIYIMA T9 Amplifier TPA3250 Tubes 2x 6K4 Bluetooth 5.0 2x60W 4 Ohm
Bon ampli
J'ai acheté cet ampli pour une pièce de 30m2. Il fait parfaitement le job. J'ai également acheté des tubes GE JAN5725 et des GE 5654 pour changer un peu de son. Et les trois paires de tubes apportent une couleurs différentes.
The Aiyima T9 is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank and without...
