1l amp pour l aigu ruban amt pro 4 et un autre pour le suraigu fostex t 90..résultat fantastique.mieux que de bons vieux classe A.
Et en prime un look sympa et une très bonne finition.
Trop fort les chinois.
This product has been replaced by the new version, the AMP25.2 Class AB Integrated Amplifier 2x30W 4 Ohm HDMI ARC.
Class AB 2x30W 4 Ohm / Bluetooth 5.0
This small integrated amplifier AMP25 in Class AB is an affordable, high-performance and stylish solution. Its MOSFET transistors based amplification stage is capable of developing no less than 2x30W at 4 Ohm, allowing it to accompany many speakers without flickering. An amplification stage that takes advantage of a symmetrical dual circuit to greatly limit interference and therefore ensure very low output noise. This design allows to obtain a precise and transparent reproduction, while developing a beautiful dynamic and a wide sound image.
For its connectivity, the AMP25 goes straight to the point by making it simple and efficient. There is therefore a Stereo RCA input to connect your source to the amplifier and at the output of the speaker terminals. However, the device is also equipped with a 6.35mm Jack plug for quality listening to headphones. All connectors are gold plated, ensuring good signal conductivity and excellent oxidation resistance.
The headset output and the speaker terminals are active simultaneously. Both are affected by the volume control.
All components are integrated in a solid solid anodized aluminum housing and cut from the black mass for the most beautiful effect. Its assertive angles and recessed volume knob give the AMP25 a strong and assertive design with the most beautiful effect.
1 | Right speaker output |
2 | Left speaker output |
3 | ON/OFF Switch |
4 | Power supply connector 12-14V DC (Power supply sold separately) |
5 | Headphone output |
6 | Stereo RCA Input |
7 | Volume button |
Product type | Integrated amplifier |
Class | AB |
Output power | 2x30W / 4 Ohm @ 12V (1% THD) |
THD | 0.008% |
Frequency response | 6Hz - 80kHz (-3dB) |
Input | 1x Stereo RCA / Bluetooth 5.0 |
Output | Speaker terminals 1x Jack 6.35mm (headphone output) |
Power supply connector | Jack DC 5.5/2.5mm |
Dimensions | 130 x 151 x 44mm |
Weight | 1150g |
Material | Massive Anodized Aluminium |
Color | Black |
Package | 1x AMP25 1x Jack 3.5mm to Jack 6.35mm adapter 1x Bluetooth Antenna 1x 1x 220V power adapter (Power cord not included, available here) |
Input | RCA |
Output | Speaker terminal |
Output | Jack 6.35mm |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | MOSFET |
Power (W) | 30.0 |
Average votes 4.9 / 5 7 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JACQUES M.
michel M.
Jean-Marie G.
Jean-François C.
Jean-François C.
