AMP35 Class AB Integrated Amplifier 2x30W 4 Ohm Bluetooth 5.0 AptX HD LDAC Black
The AMP35 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate easily into a Hi-Fi installation thanks to its sober, elegant and compact design. Its amplification power is 2x30w into 4Ω, so it's capable of driving a large number of speakers.
Reference : 18033
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 24-04-2025.
AMP35 Integrated Amplifier
Class AB 2x30W 4 Ohm Bluetooth 5.0 AptX HD LDAC Black
AMP35 Amplificateur Intégré Class AB 2x30W 4 Ohm Bluetooth 5.0 Noir
The AMP35 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate easily into a Hi-Fi installation thanks to its sober, elegant and compact design. Its amplification power is 2x30w into 4Ω, so it's capable of driving a large number of speakers. Its amplification stage is based on MOSFET transistors, two discrete single-ended AOPs and a fully symmetrical circuit. Its isolated power supply and design limit interference and noise at the output of the audio signal. Overall, the sound delivered is precise and transparent, with a wide soundstage and high dynamics.
Bluetooth 5.0 transmission
The AMP35 incorporates a Qualcomm QCC5125 Bluetooth receiver chip to support high-quality transmission codecs such as LDAC and aptX HD, as well as adaptive aptX.
Solid, elegant and compact
The AMP35's case is made of solid anodized aluminum. Its strong angles and built-in volume knob give the AMP35 a stylish, elegant appearance. In addition, the casing provides heat dissipation to match the AMP35's power.
Simple, effective connectivity
The AMP35's connectivity features a stereo RCA input and speaker terminals, as well as a 3.5mm jack for headphone listening. A "plug & play" USB-A port is also present, for connecting a source device such as a computer without having to install a driver. A Bluetooth antenna also enables remote reception of a source signal.
Both the headphone output and speaker terminals are active simultaneously, and both are affected by volume control.
1Right channel speaker terminal
2RCA input
33.5mm jack output
4Bluetooth antenna connector
5USB-A input
6Switch ON/OFF
7DC 12V-15V power supply input
8Left channel speaker terminal
Product typeIntegrated amplifier
ClassAB
ChannelsStereo (2)
Inputs1x RCA stereo
1x USB-A port
Bluetooth
OuputsSpeaker terminals
1x 3.5mm jack
Output power2x 30W / 4Ω @ 15V, 1kHz, THD+N 10%)
Distorsion0.008%
Frequency response6Hz-80kHz (-3dB)
SNR110dB
Power supplyDC 12V-15V
Dimensions150 x 150 x 50mm
Weight1.5Kg
Package1x AMP35 integrated amplifier
1x 12V power adapter (EU power cable not included, available as accessory)
1x Bluetooth antenna
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)30.0
The AMP35 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate easily...
