This is the "Neutral edition" : MASTER 9PN.
Amplificateur Double Mono Symétrique 2x70W 8Ω
The Audio-GD Master 9P is an excellent fully balanced headphone amplifier and combo amplifier, featuring the newly developed ACSS design, which provides a sound that is as accurate and transparent with XLR as with ACSS. It also benefits from an optimized power supply to provide an extremely clean and stable electrical signal to all audio circuits.
The amplifier stage of the Master 9P has a unique current gain stage (ACSS) for the shortest possible signal path and a particularly neutral and faithful sound reproduction. This ACSS amplifier has a very low distortion level and is soldered directly to the main PCB. The gain and preamplifier stages here operate in Class A. The output transistors operate with a high rest current. The special design of this stage avoids switching distortion.
The ACSS used in the Master 9P architecture is a feedback-free technology using discrete amplifiers. The combination of ACSS and a feedback-free circuitry allows for beautiful dynamics, detail and sonic neutrality, while ensuring low distortion and high linearity. The ACSS stage uses four groups of high quality Class A PSUs. This parallel connection provides a high input impedance to prevent power supply pulses from affecting the gain stages.
The Master 9P uses Linear Fidelity technology on its output stages. These have no feedback but maintain a very low level of distortion and offer excellent linear performance.
The use of high power components combined with a robust power supply ensures a high current output, allowing the Master-9P to accompany demanding loudspeakers. The Master 9P uses four channels of feedback-free output stages consisting of eight ON Semiconductor transistors, each with a power handling capacity of 230W/15A. The whole set reaches a capacity of 100000µF and two transformers are used with a power of 600W.
In order to limit the impact of different output impedances depending on the DAC used, the Master 9P uses four groups of Class A FET cascode buffers. All input signals pass through these FET buffers to achieve a low output impedance.
The Master 9P's volume control system acts at the input stage of the analog amplifier via a potentiometer allowing signal attenuation through relays and resistors. Here the volume control uses a variable passive I/V conversion at the output of the ACSS amplifier and does not degrade the signal quality.
The Master 9P features complete separation of the left and right channels of the amplifier, power supply and transformer. It also uses a heavy aluminum alloy chassis to prevent transformer eddy currents from interfering with the PCB.
Product type | Amplifier |
Amplifier type | Class A |
Inputs | 2x XLR 2x RCA 1x ACSS |
Outputs | Speaker terminals 1x Stereo XLR headphone output 1x XLR 4 pins headphone output 1x Jack 6.35mm headphone output |
SNR | > 110dB |
Gain | High gain : 34dB Low gain : 20dB |
Amplifier output power | 2x100W @ 4Ω 2x70W @ 8Ω |
Headphone output power | 2x35W @ 15Ω 2x20W @ 25Ω 2x14W @ 40Ω 2x6W @ 100Ω 2x2W @ 300Ω 2x1W @ 600Ω |
Input sensitivity | XLR : 0.55Vrms ACSS : 2mArms |
Input impedance | RCA : 47kΩ XLR : 94kΩ ACSS : < 10Ω |
THD+N | < 0.05% @ 20W, 8Ω, 1kHz < 0.002% @ 20W, 8Ω, 20kHz, 2Vrms, XLR input < 0.055% @ 60W, 8Ω, 1kHz < 0.005% @ 60W, 8Ω, 20kHz, 2Vrms, XLR input |
Supply voltage | 220-240VAC 50/60Hz |
Consumption | 50WW |
Dimensions | 430 x 430 x 93mm |
Weight | Approx. 16kg |
Color | Black |
Package | 1x Audio-GD Master-9PN 1x Power cable |
Input | RCA |
Input | ACSS |
Input | XLR |
Output | XLR |
Output | Speaker terminal |
Output | Jack 6.35mm |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 70.0 |
Remote Control | N/A |
