AUDIOPHONICS AP310-P250NC Integrated Amplifier NCore NC252MP
Versatile and powerful, we offer you with AP310-P250NC an integrated amplifier with analog inputs to which you can add speakers to enjoy your music in the best possible way. Combining a comfortable power amplification, a complete connectic and a precise volume control, this amplifier is a must have for those who wish to equip themselves with a qualitative sound system without having to add a multitude of devices dedicated to specific functions.
By buying this product you get 64 loyalty points
Reference : 18970
649,00 €tax incl.
540,83 € tax excl.
Audiophonics Workshop amplifiers range
AUDIOPHONICS AP310-P250NC Class D Integrated Amplifier NCore NC252MP 2x250W 4 Ohm
AUDIOPHONICS AP310-P250NC Class D Integrated Amplifier NCore NC252MP 2x250W 4 Ohm : Front view
Versatile and powerful, we offer you with Audiophonics AP310-P250NC an integrated amplifier with analog inputs to which you can add speakers to enjoy your music in the best possible way. Combining a comfortable power amplification, a complete connectic and a precise volume control, this amplifier is a must have for those who wish to equip themselves with a qualitative sound system without having to add a multitude of devices dedicated to specific functions.
Audiophonics AP310-P250NC: Incredibly effective amplification
The real engine of this AP310-P250NC, the Hypex NCore NC252MP Class D amplifier module delivers considerable power, up to 2x250W under 4Ω, with great efficiency and ease, while maintaining a compact size. Its main characteristic reveals itself in its great linearity and its ability to ensure a very low level of distortion. The AP310-P250NC reveals a sound reproduction as transparent as detailed to present you your music as close as possible to its recording in studio.
The NCore NC252MP also features its own SMPS power supply, consisting of a regulated half-bridge converter with synchronous rectification on the main output rails. This design is ideally suited for integration with a Class D amplifier, providing the amplifier with a stable, clean electrical signal and capable of responding quickly to more sudden power requirements.
Audiophonics AP310-P250NC: A complete connectivity to adapt to all your needs
The AP310-P250NC offers comprehensive connectivity for easy integration into your audio system and adaptation to your needs. Its rear panel features a 3-pin stereo XLR input and 4 stereo RCA inputs. On the output side, you can count on high-quality speaker terminals, as well as a Pre-Out output via RCA. The latter can also be used to connect an active subwoofer.
Audiophonics AP310-P250NC : Schéma connectique
1Pre-out RCA output
2Balanced stereo XLR input
3Single-ended stereo RCA inputs
4RCA bypass input (max fixed volume)
5Right channel speaker output
6Left channel speaker output
7Trigger input
8Trigger output
9Power input
10Fuse
11Power switch
Audiophonics AP310-P250NC: Using the Line4 bypass input (AMP-IN)
Line4 input (AMP-IN) bypasses the preamplifier stage completely. When active, no compensation or attenuation is applied to the audio signal before it is sent to the amplifier. Therefore, the source used with Line4 input must have its own volume control. This input has been designed for use as a power amplifier. It allows you to control the volume from an external preamplifier (such as an AV receiver). So, for example, you can use the AP310-P250NC as part of a home theater and HiFi setup.
Never use Line4 input without first connecting it to a source with volume control. Otherwise, the fully amplified signal could damage your speakers.
Audiophonics AP310-P250NC : Schéma branchement entrée ligne 4
Audiophonics AP310-P250NC : MUSES72320 volume controller
Audiophonics AP310-P250NC: MUSES72320 volume controller
The Audiophonics AP310-P250NC's integrated volume control features a high-quality MUSES72320 chip. This stereo electronic volume controller offers excellent performance with very low noise and distortion levels, thanks in particular to its resistor ladder circuit.
Audiophonics AP310-P250NC: A sober and modern design
The components are perfectly protected by a robust aluminum case. Optimal heat dissipation is provided by a series of openings on the cover and rear panel, allowing for good airflow. The front panel of the AP310-P250NC features a beautiful black acrylic front panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED screen, which displays the volume level, the active input or the type of signal received by the device. It will also allow you to navigate through the menus and access all the options of the AP310-P250NC.
AUDIOPHONICS AP310-P250NC Class D Integrated Amplifier NCore NC252MP 2x250W 4 Ohm : Case close-up
Product typeIntegrated amplifier
Inputs1x Balanced 3 pins stereo XLR
4x Single-ended stereos RCA
OutputsSpeaker terminals
1x Stereo RCA Pre-Out
AmplifierHypex NCore NC252MP
Amplification typeClass D
Output power2x 250W @ 4Ω
2x 150W @ 8Ω
total harmonic distortion (THD)0.0015%
Signal-to-noise ratio (SNR)121dB
Ecran OLEDBrightness not adjustable, but switches off after 40 seconds
Gain settings0dB
+6dB
+12dB
Power supply110-240V AC
ColorGray
Total dimensions (WxDxH)300*291*60mm
Weight2.5kg
CaseAll brushed aluminium / Black acrylic front
Package1x Audiophonics AP310-P250NC
1x Remote control (batteries included)
1x Power cable
InputXLR
OutputSpeaker terminal
ColorGray
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
Remote ControlYes
Quand aujourd'hui rien ni personne n'est plus fidèle, voilà au moins un produit qui respecte cette définition !
Il sera donc dit que je serais le premier à écrire un avis sur ce produit !
Comme tous les autres j’ai passé un temps infini sur le net à rechercher, comparer, étudier et finalement me décider. Le plus dur aujourd’hui c’est qu’il existe des milliers de configuration possibles mais quasiment aucune ne sont disponibles à l’écoute. Lors d’un choix les nouvelles salles d’écoute sont désormais le transport aller-retour que nous autorisent les fournisseurs : et ils ne sont pas nombreux.
Bref. Je viens d’une configuration Focal 836V + ampli NAD classe A + Caisson de basse Focal Cub + streamer Wiim pro plus + Platine Rega + vieille platine CD Philips. Ma destination : Focal Aria 906 + ampli classe D + streamer + DAC. Je garde aussi les autres vieilleries analogiques. Pourquoi un ampli classe D ? parce que j’ai eu à un moment un petit ampli Denon de cette classe qui, sans m’émerveiller, me plaisait par son côté « chirurgical ». J’ai eu aussi la possibilité (rare) d’écouter l’ampli Cambridge Audio Evo 150 qui m’a bien plu. Ce qui m’a moins séduit, c’est le tarif. Et puis la classe A, c’est bien, c’est chaud au son, mais c’est lourd et c’est un vrai barbecue.
Alors je me lance d’abord avec l’ampli Wiim Amp Pro. Belle petite boîte, fonctionnalités au top, mais manque cruel de pêche pour bouger des Focal, même petites. La scène est étroite, il manque clairement quelque chose. Cet ampli n’est pas fait pour Focal. Retour chez le fournisseur que je remercie vivement pur cet essai : maintenant un transport c’est moins cher qu’un auditorium.
Je ne retrouve donc chez Audiophonics et je me décide pour une sorte de « compromis milieu de gamme » avec cet ampli AP310-P250NC. Je vous fais grâce des mesures du site « Audio Science Review » (très bien mais peu d’informations quant à la qualité du son) et des fonctionnalités de cet appareil : chacun verra ses propres besoins. Je branche donc tout ce petit monde et immédiatement nous avons une scène large, des détails, une profondeur, largeur, hauteur, etc., etc. Tout le spectre sonore est présent y compris les basses Pas besoin d’une description de chef étoilé : l’artiste est chez moi et l’émotion est là. C’est tout ce que je demande. Même si l’ampli n’est pas concerné, j’en profite pour recommander le streamer Wiim Pro plus car les fonctionnalités sont vraiment excellentes et si le DAC n’est peut-être pas le meilleur du monde il faudra débourser beaucoup, beaucoup plus pour avoir les mêmes fonctionnalités et des performances supérieures.
Pour finir un petit mot concernant Audiophonics : tout d’abord ma commande a été livrée en 24 heures. J’achète sur internet depuis 2001. Aucun autre fournisseur n’a réussi cette performance jusque-là. Mais plus important : je suis particulièrement content d’avoir acheté un produit français. Vous allez me dire que les tripes ne sont pas françaises. Mais il y a bien longtemps que l’industrie du semi-conducteur n’est plus en France alors pourquoi investir quoi que ce soit pour faire la même chose que ceux qui sont déjà à des années-lumière de nous. Non, le vrai métier d’Audiophonics c’est le marketing achat et l’architecture des systèmes audio. Et là ils sont vraiment forts puisque leurs produits sont unanimement reconnus. S’y ajoute un service sans faille et vous avez un combo au top. Alors oui, je suis particulièrement content d’avoir acheté à une boîte française qui a tout compris, et je tiens à féliciter son dirigeant et toute l’équipe d’Audiophonics. Je vous souhaite vraiment bonne continuation et tout le succès que vous méritez.
 (7)
This review has been posted for AUDIOPHONICS AP310-P250NC Class D Integrated Amplifier NCore NC252MP 2x250W 4 Ohm
Versatile and powerful, we offer you with AP310-P250NC an integrated amplifier with analog inputs to which you can add speakers to enjoy your music...
