Je l'utilise depuis plus de 2 ans avec des enceintes DAVIS EVA ayant comme source un PC relié en USB et je suis toujours étonné de la qualité sonore de l'ensemble pour un petit budget
This product has been replaced by another version, the AUDIOPHONICS BT60W V2 Amplifier TPA3116.
HiFi USB DAC Amplifier Infineon MA12070 Bluetooth 2x55W 4 Ohm
Audiophonics offers you a revised version of the compact but no less excellent BT60W amplifier with its PRO version. On the menu of improvements: an increase in power and sound performance with the new Infineon MA12070 amplifier chip.
Now equipped with an Infineon MA12070 amplifier chip capable of delivering 2x50W of power at 4Ω, the BT60W PRO will give you a significant power boost, ideal for use with a computer, tablet or smartphone as input.
To adapt to your needs in terms of connectivity, the BT60W PRO offers a USB input and a 3.5mm jack auxiliary input. You don't want to be constrained by cables and want to stream your music from your sofa? It has a Bluetooth 5.0 controller for just that! As for the audio output, a terminal block allows you to connect the amplifier to your speakers. Finally, the power supply plug is now located on the rear panel, much more convenient for clean wiring. A volume control also allows you to easily adjust the audio level of your device.
The Bluetooth / AUX switching is done automatically by detecting the presence or not of a 3.5mm jack.
This BT60W PRO offers great versatility since in addition to being a quality amplifier, it also happens to cover the function of DAC. Moreover, the Micro-USB supports a sampling rate of 16bit / 44kHz. What to offer you a sound restitution of quality!
Designed around a black anodized aluminum and white plastic chassis, it is both extremely compact and very elegant. It will easily fit into a sound system or on your desk.
Product type | Amplifier |
Amplification chip | Infineon MA12070 |
Amplification type | Class D |
Inputs | Bluetooth 5.0 1x Micro USB 1x Jack 3.5mm |
Output | Speaker terminals |
Output power | 2x55W @ 4Ω, 24V, THD+N 1% / 2x70W @ 4Ω, 24V, THD+N 10% 2x15W @ 4Ω, 12V, THD+N 1% / 2x18W @ 4Ω, 12V, THD+N 10% |
Bluetooth range | 10m |
Supply voltage | 9-24VDC 5A (12VDC power adapter included) |
Housing material | Andoized aluminum Plastic |
Dimensions | 78 x 70 x 38mm |
Weight | 118g |
Package | 1x Audiophonics BT60W PRO 1x Power adapter 12VDC 5A 1x Male Jack 3.5mm to stereo male RCA cable 1x Jack 3.5mm cable 1.2m |
Input | Bluetooth |
Input | Jack 3.5mm |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Infineon MA12070 |
Power (W) | 55.0 |
Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Claude V.
