AUDIOPHONICS BT60W V2 HiFi USB DAC Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm
The BT60W V2 is a revised and corrected version of the excellent BT60W amplifier, more powerful and more ergonomic!
4.7 / 5
Reference : 12043
39,90 €tax incl.
33,25 € tax excl.
Audiophonics BT60W V2
Bluetooth 5.0 DAC Amplifier 2x50W
Audiophonics offers you a revised and corrected version of the compact but no less excellent BT60W amplifier with version V2. On the menu of improvements: an increase in power and more ergonomic entries.
Small but powerful
Now equipped with two 50W TPA3116D2 amplifier modules, the BT60W V2 will offer you a significant boost of power, ideal for use with a computer, tablet or smartphone as input.
Ergonomics first and foremost!
To adapt to your needs in terms of connections, the BT60W V2 offers a USB input and an auxiliary jack 3.5mm.
You do not want to be constrained by the use of cables and want to stream your music from your sofa? It comes with a Bluetooth 5.0 controller!
As for the audio output, a terminal block allows you to connect the amplifier to your speakers. Finally, the power plug is now placed on the back, much more convenient for wiringopre.
A volume control also allows you to simply adjust the audio level of your device.
The Bluetooth / AUX switching is done automatically by detecting the presence or not of a 3.5mm jack.
An amp yes, but a DAC too
This BT60W V2 offers a great versatility since in addition to being a quality amplifier, it also proves to cover the function of DAC. In addition, the Micro-USB supports a sampling rate of 16bit / 44kHz. What to offer you a sound reproduction of quality!
Designed around a chassis made of black anodized aluminum and white plastic, it is both extremely compact but also very elegant. It can be easily integrated into an audio system or on your desktop.
Connections: Inputs
Micro-USB Soundx1
3.5mm Jackx1
Bluetooth 5.0Yes
Terminal Blocks-
Amplifier Modules2x TPA3116D2
Power2x50W (4Ω)
Bluetooth range10m
SwitchOn / Off
Volume ControllerYes
Power supply (included)12V 5A via Jack DC 5.5 / 2.5mm - Accepts a voltage from 9 to 24V
Miscellaneous
Chassis materialBlack anodized aluminum and white plastic
Dimensions78 x 70 x 38mm
Weight118g
Package
3.5mm Male to RCA Stereo Male to Male Cable1x
3.5mm Male to 3.5mm Jack Cablex1
Power supply adapter 12V 5Ax1
Noticex1
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
39 reviews
Super sauf l'alim
Excellent petit ampli, pratique et quasi. Mais l'alim à découpage fait du bruit, j'envisage de la changer pour une autre.
This review has been posted for AUDIOPHONICS BT60W V2 HiFi USB DAC Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm
Surprenant
Surprenant petit ampli. Très bon rapport qualité /prix.
Attention il ne fonctionne pas et coupe épisodiquement si on monte les deux voies en parallèle pour écouter en mono sur une seule enceinte.
Utilisé dans une voiture ancienne
Je l'ai détourné de son usage principal Maison en le mettant dans ma voiture ancienne.
Branché en 12V (fusible impératif), connecté à deux HP de 40Wx4ohms chacun, c'est parfait !
Seul bémol, le son de la voix lors de l'allumage de l'ampli est un peu fort au niveau medium du son de l'ampli.
Does its job.
Bought it for BST-1 bass shakers, (simracing/music) but it was too weak for them, so I use it for smaller (15W) exciters now (Sim pedals), there its okay.
Had a faulty one that went up in smoke, got it replaced.
Knob is a little noisy when used, but other than that its okay, for the price for low wattage stuff, with integrated USB DAC its good value.
works great
everything works as described, using it to run BST-1 shaker and it works great
