Excellent petit ampli, pratique et quasi. Mais l'alim à découpage fait du bruit, j'envisage de la changer pour une autre.
Bluetooth 5.0 DAC Amplifier 2x50W
Audiophonics offers you a revised and corrected version of the compact but no less excellent BT60W amplifier with version V2. On the menu of improvements: an increase in power and more ergonomic entries.
Now equipped with two 50W TPA3116D2 amplifier modules, the BT60W V2 will offer you a significant boost of power, ideal for use with a computer, tablet or smartphone as input.
To adapt to your needs in terms of connections, the BT60W V2 offers a USB input and an auxiliary jack 3.5mm.
You do not want to be constrained by the use of cables and want to stream your music from your sofa? It comes with a Bluetooth 5.0 controller!
As for the audio output, a terminal block allows you to connect the amplifier to your speakers. Finally, the power plug is now placed on the back, much more convenient for wiringopre.
A volume control also allows you to simply adjust the audio level of your device.
The Bluetooth / AUX switching is done automatically by detecting the presence or not of a 3.5mm jack.
This BT60W V2 offers a great versatility since in addition to being a quality amplifier, it also proves to cover the function of DAC. In addition, the Micro-USB supports a sampling rate of 16bit / 44kHz. What to offer you a sound reproduction of quality!
Designed around a chassis made of black anodized aluminum and white plastic, it is both extremely compact but also very elegant. It can be easily integrated into an audio system or on your desktop.
Connections: Inputs | |
Micro-USB Sound | x1 |
3.5mm Jack | x1 |
Bluetooth 5.0 | Yes |
Terminal Blocks | - |
Amplifier Modules | 2x TPA3116D2 |
Power | 2x50W (4Ω) |
Bluetooth range | 10m |
Switch | On / Off |
Volume Controller | Yes |
Power supply (included) | 12V 5A via Jack DC 5.5 / 2.5mm - Accepts a voltage from 9 to 24V |
Miscellaneous | |
Chassis material | Black anodized aluminum and white plastic |
Dimensions | 78 x 70 x 38mm |
Weight | 118g |
Package | |
3.5mm Male to RCA Stereo Male to Male Cable | 1x |
3.5mm Male to 3.5mm Jack Cable | x1 |
Power supply adapter 12V 5A | x1 |
Notice | x1 |
Input | Bluetooth |
Input | Jack 3.5mm |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3116D2 |
Power (W) | 50.0 |
Remote Control | No |
Average votes 4.7 / 5 39 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Marc F.
Gaspard G.
Benjamin W.
Henrik H.
