AUDIOPHONICS TPA-M50 Class D Mono AmplifierTPA3116 1x60W 4 Ohm Black
The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI TPA3116D2 capable of delivering 50W of power under 8Ω, while benefiting from a Class D architecture ensuring a high efficiency of 90%.
4.5 / 5
Reference : 14006
29,90 €tax incl.
24,92 € tax excl.
Class D Amplifier TPA3116 1x50W 8Ω Noir
Audiophonics TPA-SM50 Amplificateur Mono Class D TPA3116 1x50W 8Ω Noir
The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI TPA3116D2 capable of delivering 50W of power under 8Ω, while benefiting from a Class D architecture ensuring a high efficiency of 90%. This energy reserve will allow the amplifier to accompany many speaker models or a subwoofer. Its high quality design allows it to provide low distortion, low noise and good dynamics for accurate and lively reproduction.
In addition, the amplifier also acts as a summing device, thanks to the use of a NE5532P AOP and capacitor tracking. This allows the TPA-M50 to receive a stereo signal to mix the two channels and finally output in mono, without losing the left or right channel. This function is particularly useful if the TPA-M50 is used alone and with a single speaker.
Product typeAmplifier
Amplification chipTPA3116D2
Amplification typeClass D
Power (Sous 24V)1x50W @ 8 Ohm (THD+N 0,1%)
Frequency response10Hz - 20kHz
Input1x Jack 3.5mm
Output1x Speaker terminals
Housing materialAluminium
Power supply12-26V DC via Jack DC 5.5/2.5mm (power supply sold separately)
Dimensions (LxPxH)68.5 x 115 x 37mm
InputJack 3.5mm
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipTPA3116D2
Power (W)50.0
4 reviews
Deuxième nuance
J'ai changé le câble RCA vers mini jack entre le DAC et l'ampli par un câble de 0,5 m au lieu de 2 m et cela a très nettement diminué le bruit de fond.
This review has been posted for AUDIOPHONICS TPA-M50 Class D Mono AmplifierTPA3116 1x60W 4 Ohm Black
Bruit résiduel.
Je nuance mon premier avis car comme cela a déjà été signalé il y a un bruit résiduel quand on pousse le volume. Mais comme l'ampli est très puissant ce n'est pas nécessaire.
Génial
Je viens de le recevoir. L'alim commandée séparément est plus grosse que l'ampli. Il est connecté sur une enceinte pour TV mono. Grâce à la fonction sommateur G+D les voix sont plus lisibles que si il n'y avait que la voie gauche ou la voie droite. Auparavant j'utilisais un SMSL AD18 que sur une voie. Le son est bien plus précis dans tous les registres et me semble équilibré sans agressivité. Dans la limite de l'enceinte qui n'est pas une haut de gamme (100€). Le test a été fait avec la sortie Toslink de la TV, puis un DAC SMSL à 200 € avant l'ampli. L'amélioration vient donc de l'ampli mais aussi du convertisseur puisque avant le SMSL AD18 faisait les 2.
Bon produit, conforme à la description
Léger bruit résiduel en absence de signal à l'entrée surement lié à la classe D de l'ampli.
Dommage que l'alimentation 230AC/24DC ne soit pas livrée avec (frais de port doublés si oubli) et que le bloc recommandé soit si imposant (bien plus volumineux que l'ampli car pouvant délivrer 6A alors que 3A seraient peut-être suffisants).
The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI...
