AUDIOPHONICS TPA-S120 Class D 2.1 Amplifier 2x TPA3255 Bluetooth 5.0 QCC5125 2x120W + 1x240W 4 Ohm 4 Ohm Black
The Audiophonics TPA-S120 is a Class D amplifier capable of delivering comfortable power and rich sound reproduction, all at a contained price. At the heart of it, two TPA3255 amplifier chips allow it to develop 2x120W + 1x240W under 4Ω (1% THD) with a nice dynamic and a high efficiency proper to this type of architecture. An amplifier that also wants to be versatile and easily integrated into an audio system thanks to a complete connectivity and a practical Bluetooth receiver.
4.4 / 5
Reference : 17100
219,00 €tax incl.
182,50 € tax excl.
Class D 2.1 Amplifier 2x TPA3255 Bluetooth 5.0 aptX Adaptive LDAC 2x120W + 1x240W 4Ω
Audiophonics TPA-S120 Amplificateur 2.1 Class D Bluetooth 5.0 aptX Adaptive LDAC 2x120W 4Ω
AUDIOPHONICS TPA-S120 Class D 2.1 Amplifier 2x TPA3255 Bluetooth 5.0 QCC5125 2x 120W 4 Ohm Black
Dual TPA3255 amplifier
The TPA-S120 is powered by a pair of TI TPA3255 amplifier chips capable of delivering 2x120W + 1x240W of power at 4Ω. These further ensure low distortion and beautiful dynamics for a precise and lively sound rendering. The high frequencies assert themselves with clarity but without aggressiveness, the mids offer a beautiful roundness and softness and the bass reveal themselves with firmness and power.
ES9018K2M DAC
The amplifier also benefits from the integration of a ES9018K2M DAC from ESS, in charge of the digital / analog conversion. A chip capable of an efficient decoding, essential to provide a faithful sound restitution.
Qualcomm QCC5125 Bluetooth 5.0 receiver
In addition to its physical connectivity, the TPA-S120 is equipped with a Qualcomm QCC5125 Bluetooth 5.0 receiver, making it possible to stream and control music remotely from a smartphone, tablet or any other device with this connectivity. A practical feature to access its music in a simple and fast way. It also supports aptX, aptX HD, aptX Adaptive and LDAC transmission codecs for excellent wireless sound quality.
TDA7419 DSP
The TPA-S120 also features a DSP (Digital Signal Processor) chip that allows for independent adjustment of the bass, midrange and treble levels over a range of ±15dB. The amplifier can thus be adapted to the listening preferences and audio systems of each individual without difficulty.
An efficient power supply
The TPA-S120 has its own power supply, providing a clean and stable electrical signal to all the amplifier's audio circuits. The power supply is mounted on an aluminum bracket for better heat dissipation.
Product typeAmplifier
InputsBluetooth 5.0
1* USB-B
1* Optical Toslink
1* Coaxial
1* Stereo RCA
OutputsSpeaker terminals
Speaker terminal for passive Subwoofer
1* RCA output for active Subwoofer
Puces d'amplification2* TI TPA3255
Amplification typeClass D
Output power2*120W @ 4Ω, 1% THD (Speakers)
2*140W @ 4Ω, 10% THD (Speakers)
1*240W @ 4Ω, 1% THD (Subwoofer)
1*280W @ 4Ω, 10% THD (Subwoofer)
DAC chipESS ES9018K2M
DSP chipTDA7419
OPA2* JRC 5532DD
Bluetooth receiverQualcomm QCC5125
Supported Bluetooth codecsAAC
SBC
aptX
aptX HD
aptX Adaptive
LDAC
SNR110dB
Frequency response18Hz-25kHz
Subwoofer output frequency cutout120Hz
Supply voltage100-240VAC 50/60Hz (power cable sold separately)
Dimensions (L*P*H)270*218*67mm
Weight2.44kg
Housing materialAluminum
Package1* Audiophonics TPA-S120
1* Bluetooth antenna
1* Remote control
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Channel2.1
Amplifier chipTPA3255
Power (W)120.0
Remote ControlYes
7 reviews
Hissy
Decent build quality but a bit hissy. Input display was mislabeled in my sample. Choosing USB-input did nothing but choosing BT input enabled playing music via USB, and in fact my PC recognized the amp as a BT-chip (via which, I believe, everythings internally routed). Line-level sub out is unfiltered so therefore more like a mono pre-out.
This review has been posted for AUDIOPHONICS TPA-S120 Class D 2.1 Amplifier 2x TPA3255 Bluetooth 5.0 QCC5125 2x120W + 1x240W 4 Ohm 4 Ohm Black
Super ampli
Au niveau son, rien à dire, il fait le job pour une utilisation streaming à partir d'un PC (Tidal, chaînes TV sur internet...). La puissance est suffisante pour mes petites enveintes colonne Triangle.
Mais ce qui est bluffant avec cet appareil c'est sa simplicité d'utilisation. En deux temps trois mouvement tout fonctionne, notamment l'appariement bluetooth avec tablettes et baladeurs. Par comparaison j'ai acheté un Wiim amp qui a un très bon son également mais qui m'a causé des maux de tête tant l'application est compliquée à utiliser.
Pareil au niveau design, c'est hyper sobre et ergonomique. Adieu la brique d'alimentation à découpage, le DAC séparé... On pose sur le bureau, on branche et c'est ti-par !
J'ai relevé deux petites imperfections qu'on lui pardonne volontiers : 1) il semble impossible d'éteindre l'éclairage (très puissant, et blanc contrairement à la photo 2) l'entrée USB marche mais il faut sélectionner l'entrée BT au lieu de US.
Au final, super appareil, je ne regrette pas du tout cet achat, bravo à l'atelier Audiophonics qui est compétitif par rapport aux marques chinoises. On attend les mesures sur Audio Science Reviews avec impatience !
Great Product
I am genuinely impressed with this amp.
Purchased to power some small bookshelf speakers in my office, I was impressed the first time I turned it on.
Okay, in my opinion, this is obviously not a contender for a main system. However, that said, for €220 it really does a lot right. Very surprising midrange, most of what is on the recording can be heard. What the amplifier lacks is control and refinement. But the system I generally listen to, cost rather a lot more than this. I am giving 5 stars as at this price point it is a lot better than I had expected.
If you are looking for a small low cost amp. Then I think this product will satisfy. The most important thing is to enjoy the music you are listening to. I am certainly enjoying the music in my office using this amp.
4 étoiles
Ses points forts : un punch et une énergie accompagnés d' un suivi rythmique qui procure une écoute enjouée . Une scène sonore qui s'élargit laissant place aux musiciens . J'ai était obligé d'orienter mes panneaux magnepan MG 1.7 de façon moins concentré vers le point d'écoute .
Ses points faibles : La qualité du médium notamment sur l'entrée analogique rca est limitée ( à tendance à miauler légèrement) . On retrouve ce phénomène en Bluetooth et optique mais de façon moindre . Défaut acceptable vu le prix .
Conclusion : Ecoute un peu typée mais pas caricatural ; idéal pour une chaine secondaire . Toutefois je préfère dans la même catégorie de prix SMSL en vente sur ce même site plus fidèle musicalement mais plus sage dans sa restitution .
Pas de déception niveau son c'est juste top comparé au prix, dynamique, équilibré, belle image stéréo. Dommage qu'il n'y est pas de auto ON/OFF ou timer pour un arrêt programmé.
Le DAC intégré à l'air res bien aussi, léger décrochement ( perte d'horloge surement) par moment quand je suis sur la freebox mode tv/tnt ce qui n'était pas le cas avec mon DAC magic100
The Audiophonics TPA-S120 is a Class D amplifier capable of delivering comfortable power and rich sound reproduction, all at a contained price. At...
