AUDIOPHONICS TPA-S25BT Class D Amplifier TPA3116 QCC3008 Bluetooth 5.0 2x45W 4 Ohm Gray
The Audiophonics TPA-S25BT is a compact amplifier with a low price but still offering very good sound performance. It is ideal for use with bookshelf speakers or small floorstanding speakers. The TPA-S25BT is based on a pair of TI TPA3116 amplifier chips capable of delivering 2x25W at 8 Ohm, while benefiting from a Class D architecture ensuring a high efficiency of more than 90%.
Reference : 14569
49,90 €tax incl.
41,58 € tax excl.
Class D Amplifier TPA3116 QCC3008 Bluetooth 5.0 2x25W 8 Ohm Black
Audiophonics TPA-S25BT Amplificateur Class D TPA3116 QCC3003 Bluetooth 5.0 aptX 2x25W 8 Ohm Noir
The Audiophonics TPA-S25BT is a compact amplifier with a low price but still offering very good sound performance. It is ideal for use with bookshelf speakers or small floorstanding speakers. The TPA-S25BT is based on a pair of TI TPA3116 amplifier chips capable of delivering 2x25W at 8 Ohm, while benefiting from a Class D architecture ensuring a high efficiency of more than 90%. Its quality design ensures low distortion, low noise and good dynamics for a precise and lively reproduction.
While the connection is simple, with stereo RCA input and speaker terminals output, the amplifier has the particularity of integrating a Qualcomm QCC3008 Bluetooth receiver chip, which will allow you to stream your music directly from your smartphone, tablet, or any other device with a Bluetooth transmitter. At the output of the Bluetooth chip, a PCM5102 DAC decodes the digital signal into analogue for amplification.
Finally, the front panel features a volume control knob, as well as bass and treble controls, to adapt the amplifier's performance to your audio system.
Bluetooth pairing requires a code to be entered. This code is 0123 or 0000.
On the TPA-S25BT, the Bluetooth connection takes priority. If a Bluetooth device is connected to the unit, then its RCA output is disabled. To re-enable the RCA output, it is necessary to disconnect or disable the Bluetooth connection on the source device.
Product typeAmplifier
Amplification chipTPA3116
Amplification ClassClass D
Power output2x25W @ 8 Ohm (THD+N 0.1%)
2x45W @ 4 Ohm (THD+N 0.1%)
Inputs1x Stereo RCA
Bluetooth (Code 0123 or 0000)
OutputSpeaker terminals
Bluetooth chipQCC3008
Bluetooth version5.0
Supported Bluetooth codecsSBC
AAC
AVRCP
HFP
aptX
DAC chip usedPCM5102
Power supplyJack 5.5/2.5mm (power supply sold separately)
12V: 8 ohms/ 12 + 12W , 4 ohms/ than 20 + 20W
15V: 8 ohms/ 18 + 18W , 4 ohms/ than 30 + 30W
19V: 8 ohms/ 32 + 32W , 4 ohms/ than 45 + 45W
24V: 8 ohms/ 38 + 38W , 4 ohms/ than 55 + 55W
Dimensions (without connectors)9.1 x 10.7 x 3.9cm
Weight335g
Case materialAluminium
ColorGray
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)45.0
Très satisfaisant
Produit acheté pour piloter en signal bluetooth deux enceintes 40W dans un atelier.
Le boitier est bien fini, le rapport qualité / prix est vraiment bon.
L'intégration de la réception bluetooth + du DAC dans le même boitier rend le produit efficace et peu encombrant.
Bien évidemment, ce n'est pas de l'audio ultra haut de gamme, mais pour le prix il s'agit d'un bon choix pour une installation minimale. Les réglages bass + treeble en façade permettent une bonne adaptation du signal pour exploiter les enceintes sans les faire saturer.
Attention toutefois, les alimentations proposés par audiophonics pour ce produit sont vraiment cheap. J'ai commandé une 19V 5A, et au vu de la qualité visuelle et du poix ridicule de l'alimentation, celle-ci semble vraiment de basse qualité.
This review has been posted for AUDIOPHONICS TPA-S25BT Class D Amplifier TPA3116 QCC3008 Bluetooth 5.0 2x45W 4 Ohm Gray
The Audiophonics TPA-S25BT is a compact amplifier with a low price but still offering very good sound performance. It is ideal for use with...
