CLOUDYX CL-250W A31 Amplifier WiFi DLNA AirPlay Bluetooth 5.0 HDMI 2x100W 4 Ohm
The CloudyX CL-250W A31 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It supports WiFi 2.4G and Bluetooth 5.0 to simply stream music remotely from a computer, NAS or smartphone. The amplification stage is capable of delivering a power of 2x100W under 4Ω.
4.0 / 5
Reference : 14986
159,00 €tax incl.
132,50 € tax excl.
CloudyX CL-250W A31
CloudyX CL-250W A31 Amplificateur WiFi DLNA AirPlay Bluetooth 5.0 HDMI 2x100W 4 Ohm
The CloudyX CL-250W A31 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It supports WiFi 2.4G and Bluetooth 5.0 to simply stream music remotely from a computer, NAS or smartphone. The amplification stage is capable of delivering a power of 2x100W under 4Ω. At the heart of the CL-250W A31 is a SoC MT7688 for wireless reception and data processing.
Control application
The CL-250W A31 can be controlled via the Muzo mobile application. This application makes it easy to manage broadcasting and playback through an ergonomic and intuitive interface.
The application is also compatible with many popular streaming services such as Qobuz, Deezer or Napster.
CloudyX CL-250W A31 Amplificateur WiFi DLNA AirPlay Bluetooth 5.0 HDMI 2x100W 4 Ohm CloudyX CL-250W A31 Amplificateur WiFi DLNA AirPlay Bluetooth 5.0 HDMI 2x100W 4 Ohm
Application mobile Android Play Store Application mobile iOS App Store
1ON/OFF Switch
2Jack 3.5mm headphone output
3Volume / Function button
4WiFi/AUX input LED
5Bluetooth input LED
6HDMI input LED
7Optical input LED
8Bass setting LED
9Treble setting LED
10IR Receiver
11Reset button
12RJ45 input
13Optical Toslink input
14ARC HDMI input
 15AUX input
16Jack 3.5mm line output
17Optical Toslink output
18Subwoofer output
19Upgrade interface
2012VDC Power supply
21Right channel speaker terminal
22Left channel speaker terminal
23Right channel speaker terminal
24WiFi antenna
25Bluetooth antenna
Technical characteristics
Product typeAmplifier
Power2x 100W @ 4Ω
InputWiFi
Bluetooth 5.0
1x RJ45 (Ethernet)
1x Optical Toslink
1x Jack 3.5mm line input
1x HDMI ARC
OutputsSpeaker terminals
1x Jack 3.5mm line output
1x Optical Toslink
1x RCA subwoofer output
1x Jack 3.5mm headphone output
THD0.05%
SNR95dB
AUX Input sensitivity1V
RCA output level1V
Power supply32V DC 5A
Dimensions225 x 202 x 45mm
Package1x CloudyX CL-250W A31
2x Antenna
1x Power supply
1x RCA Cable
1x Jack 3.5mm cable
1x RCA to Jack 3.5mm cable
1x Remote control (requires 2 AAA batteries not included)
InputRJ45
InputWiFi
InputJack 3.5mm
InputHDMI
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
OutputOptical Toslink
DAC / ADC ChipNC
Max sampling rateNC
Channel2 (Stereo)
Amplifier chipN/A
Power (W)100.0
Oui, il existe !
Si comme moi vous avez cherché un peu partout sur internet des informations sur cet ampli, je vais essayer de faire office de documentation.
Je l'ai reçu en 2 jours bien emballé comme toutes mes commandes audiphonics. J'ai été tout d'abord surpris par le minimalisme du packaging, il n'y a pas de notice, pas d'informations, et même pas de piles pour la télécommande ! Il vous faudra 2 piles AAA pour cette dernière.
Je vais tout de suite parler du principal défaut que j'ai pu lui trouver ; les boutons 'volume -', 'wifi' et 'mute' de la télécommande affectent aussi ma télé Hisense, mais je pense que je suis un cas particulier et que si vous avec une autre télé vous ne devriez pas avoir de soucis.
Coté entrées/sorties tout fonctionne, notez que la sortie ligne est controlée par le bouton volume, ce qui peut être aussi un avantage si vous y connectez un appareil sans télécommande comme un ampli casque.
L'entrée Wifi correspond entre autres à airplay, pour connecter votre appareil au réseau wifi vous aurez besoin d'une application chinoise obscure 'Muzo Player' qui en profitera pour récupérer vos données de localisation. La bonne nouvelle c'est que vous pouvez la supprimer après le paramétrage, et votre ampli se comportera exactement comme un appareil airplay classique. Pour plus d'informations sur le paramétrage j'ai trouvé une vidéo youtube perdue : /watch?v=h-6jO_g3h8k . Remarque : la led qui correspond à l'entrée Aux et Wifi est la même, mais on peut quand même sélectionner l'une ou l'autre en appuyant sur le bouton volume.
J'ai branché un dt1770 pro (250ohm) sur la sortie casque et le son est très bon. On sent que l'impédance est un peu élevée pour ce petit ampli quand on met des musiques très punchy mais rien de grave, sur les musiques plus 'douces' le son est très propre.
Je n'ai pas encore branché mes enceintes dessus car je ne les ai pas reçu, je ferai une update si jamais je remarque quelque chose de particulier, mais je ne me fais pas de soucis.
Il n'y a pas de 'patins' dessous comme peuvent le laisser penser les photos, mais ce n'est pas très grave on peut en rajouter facilement. J'ai essayé de retourner les faces latérales pour pouvoir le fixer sous une planche de meuble, mais c'est malheureusement impossible car les faces supérieures et inférieures ne sont pas symétriques, si vous voulez faire ça il vous faudra bricoler un peu.
Dernière remarque sur le bouton marche/arrêt qui est très agréable, avec un contour en métal, et un éclairage blanc quand il est en marche. C'est un bouton physique qui reste enfoncé quand l'appareil est allumé, et reviens en avant quand on l'éteint.
En conclusion je dirais que c'est vraiment un bon petit ampli, ses petits défauts se font oublier quand on voit son prix, sa taille, et son look.
This review has been posted for CLOUDYX CL-250W A31 Amplifier WiFi DLNA AirPlay Bluetooth 5.0 HDMI 2x100W 4 Ohm
The CloudyX CL-250W A31 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It...
