CLOUDYX CL-300W A98 Amplifier WiFi DLNA AirPlay2 Bluetooth 5.0 2x275W 4 Ohm
The CloudyX CL-300W A98 is a powerful and versatile integrated amplifier with advanced connectivity including Bluetooth 5.0 and WiFi integration. The device also features a phono (MM) input, which is handy for enjoying your vinyl records.
By buying this product you get 38 loyalty points
Reference : 14988
389,00 €tax incl.
324,17 € tax excl.
CloudyX CL-300W A98
CloudyX CL-300W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 2x275W 4 Ohm
Note: This product offers many features, only its design with integrated DSP does not offer the transparency sought by audiophiles. The analog input also goes through the DSP via an ADC. We want this for someone who is looking for a network amplifier that supports many music services and protocols with comfortable power, but without the pursuit of high fidelity.
1Screen
2Volume / Function button
3Microphone antenna
4Pairing / Reset switch
5RJ45 (LAN) input
6Optical Toslink input
7HDMI input
8USB-A input
9Stereo RCA input
10Phono MM input
11Stereo RCA output
12Subwoofer output
13Optical Toslink output
14Right channel speaker terminals
15Left channel speaker terminals
16Power supply connector
17Power button
18Bluetooth & WiFi antenna
Phono input & RIAA curve
The CL-300W features an RCA phono (MM) input, allowing a vinyl turntable to be connected to it. This input is combined with an RIAA phono preamplifier that can restore the timbre of the original vinyl recording for a rich and detailed musical experience.
TPA3255 Amplifier
At the heart of the CloudyX CL-300W's amplification stage is a TPA3255 chip. It benefits from a Class D architecture and delivers a significant power of 2x 275W at 4Ω, with a high efficiency. In addition, this chip integrates a feedback system and the proprietary PurePath Ultra HD technology. The latter enables extremely low distortion across the entire bandwidth, while providing superior sound quality.
Multiroom & Control app
The CL-300W will allow you to easily set up a multiroom system to enjoy your music in all your rooms. Playback control is simple with the Muzo control application, available free of charge on Android and iOS. In addition, it will allow you to enjoy your favorite streaming services such as Qobuz, Spotify or Deezer.
CloudyX CL-300W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 2x275W 4 Ohm CloudyX CL-300W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 2x275W 4 Ohm
Application Muzo Android Play Store Application Muzo iOS App Store
Amazon Alexa Compatible
The CL-300W is also compatible with Amazon Alexa, allowing voice control of playback and multiroom.
Product typeAmplifier
Power2x 275W @ 4Ω
2x 150W @ 8Ω
InputsWiFi 2.4G / 5G
Bluetooth 5.0
1x Phono (MM) RCA input
1x USB-A Host
1x HDMI
1x Optical Toslink
1x RJ45
1x Stereo RCA
Mic reception
Outputs1x Stereo RCA
1x RCA subwoofer output
1x Optical Toslink
Speaker terminals
THD0.05%
Impedance2kΩ
SNR95dB
AUX Input sensitivity1V
Phono input sensitivity5mV
RCA output level1V
Supported WiFi protocolsDLNA
AirPlay2
Supported streaming servicesiHeartRadio
Spotify
Tidal
Napster
Qobuz
Deezer
Mobile appiOS / Android compatible
Supported sampling ratesPCM up to 24bit 192kHz
MultiroomLinkPlay MRM / Amazon MRM compatible
Supported HDMI technologyARC
Power supply100-240V
Dimensions28 x 23 x 6cm
Weight1.5kg
Package1x CloudyX CL-300W A98
1x Power cable
1x Remote control
InputRJ45
InputWiFi
InputHDMI
OutputSpeaker terminal
OutputSubwoofer
OutputOptical Toslink
DAC / ADC ChipNC
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)275.0
The CloudyX CL-300W A98 is a powerful and versatile integrated amplifier with advanced connectivity including Bluetooth 5.0 and WiFi integration....
