DAYTON AUDIO DTA-100LF Low Frequency Amplifier with EQ for Subwoofer and Exciter
Dayton Audio's DTA-100LF is a Class D low frequency amplifier specifically designed to drive a subwoofer or vibrator. Powerful, it is able to develop a maximum power of 100W under 4Ω or 70W under 8Ω. It also includes three crossovers and a variable phase control to protect, integrate and tune your speakers in any system.
Reference : 15950
169,00 €tax incl.
140,83 € tax excl.
Dayton Audio DTA-100LF
Dayton Audio DTA-100LF Amplificateur Basses Fréquences avec Égaliseur pour Subwoofer et Vibreur
An adjustable subsonic crossover is used to protect the speakers from over-excursion. A low-pass filter allows the speakers to be integrated with full-range speakers. Finally, a single-band parametric crossover helps manage peaks that may arise from the room acoustics themselves.
The Dayton Audio DTA-100LF is also capable of detecting an input signal to automatically turn on and off. It also comes in a convenient compact case with brackets for mounting under a shelf or desk, for example.
To use the power cable on European/French power outlets, an adapter sold separately is required.
Product typeLow frequency amplifier
Input1x Stereo RCA
Outputs1x Stereo RCA
Speaker terminals
Max output power100W @ 4Ω
70W @ 8Ω
THD< 1%
Frequency response20Hz - 180Hz ±3dB
SNR95dB
Input sensitivity200mV
Low pass crossover range30Hz - 200Hz
Phase adjustment0° - 180° variable
Line input impedance22kΩ
Line output impedance4kΩ
Supply voltage120-240VAC
ConsumptionMax : 150W
Standby : 1.8W
Dimensions190.5 x 139.7 x 50.8mm
Weight1.5kg
OutputSpeaker terminal
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipN/A
Power (W)100.0
Dayton Audio's DTA-100LF is a Class D low frequency amplifier specifically designed to drive a subwoofer or vibrator. Powerful, it is able to...
