DYNAVOX VT-60 Class AB Amplifier 2x30W 4 Ohm
Dynavox proposed with the VT-60 a stereo amplifier in Class AB, capable of delivering a power of 2x30W at 4 Ohm. The VT-60 has a simple, sober and elegant design, and its proven design allows it to offer a beautiful sound reproduction: well placed bass and a large sound stage characterize this VT-60.
Reference : 13937
219,00 €tax incl.
182,50 € tax excl.
Dynavox VT-60
Dynavox VT-60 Amplificateur Class AB 2x30W 4 Ohm
On the connector side, there are simply 4 stereo RCA inputs and a 3.5mm jack on the front panel, the latter allowing for example to connect a smartphone or a tablet. For its outputs, in addition to the classic speaker terminals, the VT-60 has a REC Out stereo RCA output for connecting recording devices.
Finally, there is a large volume control knob on the front panel, a source selector, as well as buttons to adjust bass, treble and balance levels.
Product typeAmplifier
Amplification typeClass AB
Power2x30W @ 4Ω
Frequency response10Hz - 30kHz (-3dB)
Impedance4-8Ω
Distortion> 82dB (1W)
< 0.07% (1kHz)
Input sensitivity110mV (30W)
Supply voltage230V 50Hz (power cable included)
ConsumptionMax. 160W
Inputs4x Stereo RCA
1x Jack 3.5mm
Outputs1x Stereo RCA (REC Out)
Speaker terminals
Dimensions430 x 70 x 284mm
Weight4.7kg
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)30.0
Dynavox proposed with the VT-60 a stereo amplifier in Class AB, capable of delivering a power of 2x30W at 4 Ohm. The VT-60 has a simple, sober and...
