FOSI AUDIO BT20A Class D Amplifier 2x TPA3116 Bluetooth 5.0 2x90W 4 Ohm
The Fosi Audio BT20A is a compact and powerful Class D amplifier, offered at a contained price. Its amplifier stage uses not one but two TI TPA3116D2 chips, capable of developing a power of 90W under 4Ω per channel.
Reference : 17193
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 22-04-2025.
Fosi Audio BT20A
Class D amplifier 2x90W 4 Ohm - Bluetooth 5.0
Fosi Audio BT20A Amplificateur
The Fosi Audio BT20A is a compact and powerful Class D amplifier, offered at a contained price. Its amplifier stage uses not one but two TI TPA3116D2 chips, capable of developing a power of 90W under 4Ω per channel. All this while providing a clear and detailed sound reproduction.
The BT20A is simple and efficient, with stereo RCA and Bluetooth 5.0 inputs and gold-plated speaker terminals at the output.
This product has a front panel tone control that allows you to adjust the bass and treble levels to suit your audio system and preferences.
A Bluetooh code may be required to connect to the amplifier, this is "0000" or "1234".
Technical specifications
Type of productStereo amplifier
Type of amplificationClass D
Inputs1x RCA stereo
Bluetooth 5.0
OutputSpeaker terminals
Amplification chips2x TI TPA3116D2
Power2x 90W @ 4Ω, 24V, 1% THD
2x 50W @ 8Ω, 24V, 1% THD
Frequency response20Hz-50kHz (±2dB)
THD≤ 0.04%
SNR≥ 98dB
Input sensitivity280mV
Tone controlBass / Treble
Power supply voltage15 - 24VDC (AC adapter included)
Dimensions (L*P*H)130x100x35mm
Net weight700g
Package1x Fosi Audio BT20A
1x Power supply 24V 4.5A
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)90.0
2 reviews
Impeccable pour une TV
J’ai choisi cet ampli pour améliorer le son de ma TV Samsung qui date d’une douzaine d’années, en réutilisant des enceintes Elipson qui dormaient dans un coin.
Pari réussi. C’est pas du 5.1 certes, mais ça me suffit amplement, le son est largement meilleur que celui des hauts parleurs de la TV.
Le seul petit souci que j’ai eu, c’est pour relier les câbles de mes enceintes en 2,5 mm2 car les borniers de l’amplificateur sont un peu petits. D’ailleurs, l’ampli est lui-même riquiqui, c’est assez bluffant de voir qu’un si petit objet puisse produire un son si puissant…
This review has been posted for FOSI AUDIO BT20A Class D Amplifier 2x TPA3116 Bluetooth 5.0 2x90W 4 Ohm
High value for you're money
Very harmonic amp, tone controls adjusted since 12 o'clock might not be 100% neutral, i feel i don't miss anything except when playing loud, there are other amps that can play louder and are more suitable for low sensitive speakers,no pop sound turning it on,off which is super, fast connection via bluetooth and as soon as it's on theres sound, if the source is playing, low price considering you get a 24 volt psu and it looks good to. Driving triangle esprit titus ez
The Fosi Audio BT20A is a compact and powerful Class D amplifier, offered at a contained price. Its amplifier stage uses not one but two TI...
