Pour le prix est vraiment un bon produit .
Class D 2.1 Amplifier 2xTPA3255 Bluetooth 5.0 2x125W+250W 4 Ohm
The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It embeds for that two TPA3255 amplification chips allowing him to develop a comfortable power of 2x 125W under 4Ω with a high efficiency proper to the Class D architectures. To that, the DT30D Pro adds a subwoofer output providing it 250W, allowing the use of a subwoofer for deeper bass. The amplifier also features a tone control that allows you to adjust the bass, treble, subwoofer and crossover frequency independently. It can therefore be easily adapted to any audio distribution system.
On the connectivity side, once again, the DT30D Pro aims at simplicity and efficiency. The outputs are on speaker terminals or via a pre-out output in 3.5mm jack format. For the inputs, the DT30D Pro offers stereo RCA but also Bluetooth 5.0. It is therefore possible to broadcast and control your music remotely, from a smartphone or a tablet for example.
Product type | Amplifier |
Inputs | Bluetooth 5.0 1* Stereo RCA line input |
Outputs | Speaker terminals Subwoofer output on speaker terminals 1* Pre-Out on Jack 3.5mm |
Amplification chip | 2*TPA3255 |
Output power | 2 * 125W + 250W @ 4Ω, 1% THD / 36V DC 2 * 160W + 300W @ 4Ω, 10% THD / 36V DC |
THD | ≤ 0.03% |
SNR | 108dB |
Frequency response | 20Hz - 20kHz |
Subwoofer frequency cut-off | 20-300Hz |
Supply voltage | 12-36VDC (32VDC power supply included) |
Color | Black |
Package | 1* Fosi Audio BT30D Pro 1* Power supply 32VDC 5A 1* Bluetooth antenna |
Input | Bluetooth |
Input | RCA |
Output | Jack 3.5mm |
Output | Speaker terminal |
Output | Subwoofer |
Color | Black |
Channel | 2.1 |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 125.0 |
Remote Control | No |
Average votes 3.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bruno S.
Jean-François C.
