FOSI AUDIO E10 PRO Amplifier TPA3251D2 MS8413 Bluetooth 5.0 24bit 192kHz 2x125W 4 Ohm
The Fosi Audio E10 is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to develop a comfortable power of 2*125W under 4Ω with a high efficiency, a low distortion and a wide dynamic range, for a sound restitution as precise as musical.
By buying this product you get 22 loyalty points
Reference : 17007
229,00 €tax incl.
190,83 € tax excl.
Fosi Audio E10 Pro
Amplifier TPA3251D2 MC8413 Bluetooth 5.0 24bit 192kHz 2x125W 4Ω
Fosi Audio E10 Pro Amplificateur TPA3251D2 MC8413 Bluetooth 5.0 24bit 192kHz 2x125W 4Ω
The Fosi Audio E10 Pro is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to develop a comfortable power of 2*125W under 4Ω with a high efficiency, a low distortion and a wide dynamic range, for a sound restitution as precise as musical. Moreover, the E10 Pro offers a complete range of connectors allowing it to adapt to most of the use scenarios. We find stereo RCA, Toslink optical, coaxial and a USB-A port for storage device, completed by a Bluetooth 5.0 reception capacity. Practical, the latter offers the possibility of broadcasting and controlling its music remotely easily from a smartphone or a tablet for example. On the output side, the amplifier offers of course speaker terminals but also a pre-out RCA output that can be used as a subwoofer output. The front of the E10 Pro also features a beautiful color screen.
1Power button
2USB-A input
3Previous track button
4Play button
5Nex track button
6Input selection button
7Volume button
8Bluetooth antenna connector
9Coaxial input
10Optical Toslink input
11RCA 1 input
12RCA 2 input
13RCA / Subwoofer output
14Right channel speaker output
15Left channel speaker output
16Power supply input
Product typeAmplifier
InputsBluetooth 5.0
2* Stereo RCA
1* USB-A (USB Host)
1* Optical Toslink
1* Coaxial
OutputsSpeaker terminals
1* Steroe RCA / Subwoofer output
Amplification chipTPA3251D2
DAC chipMS8413
Bluetooth chipATS2825
Output power2* 125W @ 4Ω, 1% THD
Frequency response10Hz - 60kHz (±6dB)
SNR92dB
Dynamic range105dB
THD≤ 0.01%
Supported sampling rates (optical/coaxial)PCM up to 24bit 192kHz
Supply voltage220-250VAC (power cable included)
Dimensions (W*D*H)460*400*170mm
ColorFront panel : Silver
Rest of the body : Black
Package1* Fosi Audio E10
1* Power cable
1* Antenna
1* Remote controle
1* RCA cable
OutputSpeaker terminal
OutputSubwoofer
ColorSilver
Channel2.1
Channel2 (Stereo)
Amplifier chipTPA3251D2
Power (W)125.0
The Fosi Audio E10 is a Class D amplifier that is both powerful, efficient and affordable. It embeds a TPA3251D2 amplifier chip allowing it to...
