FOSI AUDIO TP-03 Class D Amplifier Mono + Subwoofer
The Fosi Audio TP-03 mono + subwoofer amplifier is compact but efficient. It features an ST TDA7498E amplifier chip, delivering 220W of power at 4 Ohms. It features two operating modes selectable on the front panel, enabling it to power either an active or passive subwoofer, or a passive speaker, depending on the setting of the frequency potentiometer. The latter also allows adjustment of the 20Hz - 300Hz low-pass filter. Simple and effective, this subwoofer amplifier also features a phase inversion option, enabling it to drive a large number of subwoofers available on the market.
Reference : 18834
79,00 €tax incl.
65,83 € tax excl.
Fosi Audio TP-03 Class D Amplifier Mono + Subwoofer TDA7498E 120W 4 ohm
Fosi Audio TP-03 : front view
The Fosi Audio TP-03 mono + subwoofer amplifier is compact but efficient. It features an ST TDA7498E amplifier chip, delivering 220W of power at 4 Ohms. It features two operating modes selectable on the front panel, allowing you to choose between powering an active or passive subwoofer, in which case you'll need to set the frequency potentiometer (FREQ) to "Direct". Or it can power a passive speaker, in which case you'll need to set the frequency potentiometer to "Tone High". Note also that the latter allows adjustment of the 20Hz - 300Hz low-pass filter. Simple and effective, this subwoofer amplifier also features a phase inversion option, enabling it to drive a large number of subwoofers available on the market. A 24V DC 4.5A power supply is supplied.
Fosi Audio TP-03: a ST TDA7498E amplifier chip
Fosi Audio has chosen to integrate an ST TDA7498E amplifier chip for its TP-03 amplifier. This STMicroelectronics chip is a Class D amplifier. In particular, it features a "Standby and mute" function, allowing golden silence, devoid of the slightest background noise when no signal is sent to the Fosi TP-03.
Puce ST TDA7498E
Fosi Audio TP-03 overview
Fosi Audio TP-03 explanatory diagram
1Power Switch
2Power Light
3Phase Adjustment
4Subwoofer (FREQ adjust) & Full frequency output
5Volume Adjustment
6RCA Input
73.5mm AUX Input
8Speaker Output
Product typeMono + Subwoofer amplifier
Amplification chipST TDA7498E
Input1x RCA input
3.5mm Jack
Output1x Bornier enceintes
Output power220W
Output impedance
Input sensitivity≤ 0.2mV
Frequency response20Hz - 20KHz (±3db)
Bass frequency range20Hz - 300Hz
Total harmonic distortion (THD)≤0.03%
Signal-to-noise ratio (SNR)≥ 106dB
Power supply range19V - 32V DC
Net weight1kg
Dimensions12.7 x 7.42 x 2.54 cm
Package1x Fosi Audio TP-03
1x Power Adaptter 24v 4,5A
1x User Manual
InputJack 3.5mm
OutputSpeaker terminal
Channel1 (Mono)
Amplifier chipTDA7498E
Power (W)220.0
FOSI AUDIO TP-03 Amplifier Class D Mono + Subwoofer TDA7498E 220W 4 Ohm
The Fosi Audio TP-03 mono + subwoofer amplifier is compact but efficient. It features an ST TDA7498E amplifier chip, delivering 220W of power at 4...
