FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Silver
The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a CS8673E chip allowing it to develop a power of 2x65W under 4Ω, allowing it to power many bookshelf or floorstanding speakers.
Reference : 16147
44,90 €tax incl.
37,42 € tax excl.
FX-Audio 502E-L
FX-Audio 502E-L Amplificateur Class D CS8673E Bluetooth 5.0 2x65W 4 Ohm
The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a CS8673E chip allowing it to develop a power of 2x65W under 4Ω, allowing it to power many bookshelf or floorstanding speakers. Moreover, the amplifier benefits from a front panel bass and treble adjustment on a range of +7dB to -7dB, in order to adapt the sound reproduction to your audio system and your listening.
In terms of connectivity, the 502E-L is simple and practical. The input is a stereo RCA as well as a Bluetooth reception allowing you to broadcast your music remotely, from a smartphone for example. The output is classically done on speaker terminals, accepting banana plugs.
Product typeAmplifier
Amplification typeClass D
InputsBluetooth 5.0
1x Stereo RCA
OutputSpeaker terminals
Amplification chipCS8673E
Bluetooth chipAC6951A
OPANE5532
MultiplexerSGM4806
THD+N< 0.05% @ 1kHz A-Weighting
SNR85dB @ 1kHz A-Weighting
Frequency response20Hz-20kHz (±3dB)
Tone controlsTreble : ±7dB
Bass : ±7dB
Output power2x65W @ 4Ω, THD+N 1%, DC=24V
2x34W @ 8Ω, THD+N 1%, DC=24V
2x75W @ 4Ω, THD+N < 10%, DC=24V
2x40W @ 8Ω, THD+N < 10%, DC=24V
Efficiency> 90%
Compatible impedances4-16Ω
Supported Bluetooth codecsSBC, AAC (V5.1 + BR + EDR + BLE)
Supply voltage19-24VDC 4A (power supply included)
ColorSilver
ColorSilver
Channel2 (Stereo)
Amplifier chipCS8673E
Power (W)65.0
3 reviews
Excellent ampli
J'ai ajouté cet ampli FX audio associé avec mes Bose acoustimass 5 série 3, le son est nickel, dynamique, pas agressivite pour un ampli classe d, je trouve le bouton de réglage du volume un peu juste au niveau puissance presque aux max mais dans ensemble c'est très bien et hyper correct vu son prix, franchement rien à dire
This review has been posted for FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Silver
Ampli
Bonjour je viens de recevoir mon petit ampli pour ma télé, c'est génial,super son et simple à utiliser,pour un prix défiant toute concurrence,parfait et envoi ultra rapide ,merci.
Cordialement.P.F
rapport qualité /prix
Difficile de lui reprocher quelque chose à ce prix , un ampli simple et efficace drive honorablement des davis mia20
merci fx audio et surtout merci audiophonics
The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture,...
