FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Black
The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a CS8673E chip allowing it to develop a power of 2x65W under 4Ω, allowing it to power many bookshelf or floorstanding speakers.
3.0 / 5
Reference : 16146
44,90 €tax incl.
37,42 € tax excl.
FX-Audio 502E-L
FX-Audio 502E-L Amplificateur Class D CS8673E Bluetooth 5.0 2x65W 4 Ohm
The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a CS8673E chip allowing it to develop a power of 2x65W under 4Ω, allowing it to power many bookshelf or floorstanding speakers. Moreover, the amplifier benefits from a front panel bass and treble adjustment on a range of +7dB to -7dB, in order to adapt the sound reproduction to your audio system and your listening.
In terms of connectivity, the 502E-L is simple and practical. The input is a stereo RCA as well as a Bluetooth reception allowing you to broadcast your music remotely, from a smartphone for example. The output is classically done on speaker terminals, accepting banana plugs.
Product typeAmplifier
Amplification typeClass D
InputsBluetooth 5.0
1x Stereo RCA
OutputSpeaker terminals
Amplification chipCS8673E
Bluetooth chipAC6951A
OPANE5532
MultiplexerSGM4806
THD+N< 0.05% @ 1kHz A-Weighting
SNR85dB @ 1kHz A-Weighting
Frequency response20Hz-20kHz (±3dB)
Tone controlsTreble : ±7dB
Bass : ±7dB
Output power2x65W @ 4Ω, THD+N 1%, DC=24V
2x34W @ 8Ω, THD+N 1%, DC=24V
2x75W @ 4Ω, THD+N < 10%, DC=24V
2x40W @ 8Ω, THD+N < 10%, DC=24V
Efficiency> 90%
Compatible impedances4-16Ω
Supported Bluetooth codecsSBC, AAC (V5.1 + BR + EDR + BLE)
Supply voltage19-24VDC 4A (power supply included)
Dimensions11x10x3.5cm
Channel2 (Stereo)
Amplifier chipCS8673E
Power (W)65.0
Compact et efficace, Bluetooth hs
Utilisé pour des enceintes de bureau faites maison pour alimenter des Hp de voiture de 40 w RMS montés dans des caisson. ca marche super bien câblé, Pour ce qui est du Bluetooth, impossible de le faire fonctionner.
l'appareil est détecté par mon téléphone mais impossible de l'appairer. il indiquent dans la notice une application pour le faire fonctionner mais qui est ecrite tout en Chinois et impossible de faire une traduction, amoins que vous sachier le parler et l'écrire, c'est inutilisable.
il est important de souligner la taille du produit sur le site, ou je m'atendait a beaucoup plus gros, a ma grande surprise il fait 10.5 cm par 9.5 cm sur 3 cm de hauteur.
Pour conclure, compact, efficace rendu du son ok, bluetooth ne fonctionnant pas. bien construit tout en métal.
rien a dire en cablé.
This review has been posted for FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Black
The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture,...
