FX-AUDIO FX252A Class D TDA7492E Amplifier 2x68W 4 Ohms Silver
Reference : 13327
34,90 €tax incl.
29,08 € tax excl.
FX-Audio FX252A
FX-Audio FX252A Amplificateur Class D TDA7492E 2x68W 4 Ohms Noir
FX-Audio offers with its FX252A a Class D amplifier capable of delivering up to 2x68W at 4 Ohms in a very small format.
ST Electronics TDA7498E
The FX252A integrates a ST Electronics TDA7498E amplifier chip. This allows you to deliver a power of 2x68W 4 Ohms and takes advantage of the high efficiency of a Class D amplifier to provide the necessary power to your speakers. It incorporates a noise reduction system and protection against short circuits and excessive temperatures. In addition, it allows you to simply select the fixed gain via the DIP Switches under the unit at the following values: 20.8dB, 26.8dB, 30dB and 32.8dB.
Quality components
The amplifier benefits from a high quality design and components. A series of capacitors reduces residual noise and distortion, and a YXG Rubicon capacitor ensures a stable and clean power supply. The connectors, on the other hand, are gold-plated to ensure good conductivity and durability.
Elegant design
Habillé d'un boîtier noir en aluminium brossé avec façade argent, cet amplificateur FX-Audio FX252A affiche un design à la fois sobre mais élégant, qui saura s'intégrer au sein de votre système audio.
Product typeClass D amplifier
Amplification chipTDA7492E
InputStereo RCA
OutputSpeaker terminal
Connectors platingGold
Output power2x68W @ 24V 4 Ohm
Efficiency> 85%
Supported impedance4 - 16 Ohm
Power supply15V DC 4A (included) via Jack DC 5.5/2.1mm (Possibility to upgrade to a 24V 5A power supply)
Housing materialAluminium
ColorBlack with silver front panel
Weight340g
Dimensions98 x 123 x 33mm
ColorSilver
Channel2 (Stereo)
