FX-AUDIO M160E Class D Amplifier TDA7498E Bluetooth 4.0 2x100W 4 Ohm
The FX-Audio M160E is an amplifier capable of developing 2x125W under 4 Ohm. In addition, its Class D design allows it to benefit from high efficiency and therefore to be associated with many speakers, including demanding models.
2.8 / 5
Reference : 13433
69,90 €tax incl.
58,25 € tax excl.
FX-Audio M160E
FX-AUDIO M160E Amplificateur Class D TD7498E Bluetooth 4.0 2x138W
The FX-Audio M160E is an amplifier capable of developing 2x100W under 4 Ohm. In addition, its Class D design allows it to benefit from high efficiency and therefore to be associated with many speakers, including demanding models. To do this, it is based on a high-performance TDA7498E amplification chip. There is also a USB DAC PCM2704 from Texas Instruments that converts up to 48kHz.
As for connectivity, there is a USB-B 2.0, a RCA Stereo, an SD slot and a USB-A 2.0 for your storage devices (USB key, hard disk...). The amplifier also includes a CS8635 Bluetooth chip to stream your music directly from your smartphone or tablet.
Product typeAmplifier
ClassD
Power2x125W @ 4 Ohm at 32V (THD 10%)
2x 100W @ 4 Ohm at 32V (THD 0.1%)
2x60W @ 8 Ohm at 32V (THD 10%)
Inputs1x USB-B 2.0
1x Stereo RCA
1x USB-A
1x SD card slot
Bluetooth
OutputSpeaker terminals
Impedance4-8 Ohm
THD0.15%
SNR85dB
Power supply32V DC 5A (included)
Dimensions13 x 11 x 3.2cm
Weight1.15kg
Package1x M160E
1x Power supply
1x Remote control
InputSD Card
Channel2 (Stereo)
Amplifier chipTDA7498E
Power (W)138.0
5 reviews
Il n'y a pas de miracle !
Je cherchais un petit ampli pour l’associer à mon PC, avec un encombrement réduit et une connectivité multiple pour un budget max de 150€.
Après lecture des caractéristiques techniques de ce modèle, tout semblait OK.
Fonctions de connexions multiples, pratique pour son encombrement, prix réduit etc...
Mais à la première écoute, on redescend vite.. et finalement, il n'y a pas de miracle!
Le souffle est présent et insupportable (Je ne suis pas un puriste de la HIFI et pourtant..) . A me demander si mon modèle n' a pas un problème...
Pour le reste j'ai testé les connexions bluetooth , USB et RCA qui font le travail. La télécommande est réactive et simple d'utilisation. La puissance est également présente mais la distorsion est très perceptible dès que l'on monte un peu le volume.
Je reste très déçu du produit.
Le revendeur est très sérieux et l'emballage était soigné.
Bonjour,
Il est possible que le niveau d'entrée de votre source soit trop élevé entrainant les symptômes que vous avez rencontré.
This review has been posted for FX-AUDIO M160E Class D Amplifier TDA7498E Bluetooth 4.0 2x100W 4 Ohm
Un ampli aux défauts importants
J'avais choisi cet ampli pour sa connectivité USB/SD et Bluetooth ainsi que son faible encombrement et son prix. Lors de ma première écoute, le bruit de l'ampli m'a instantanément gêné, de même que la distorsion importante qui se transforme en souffle à volume plus soutenu. Finalement je préfère le Topping MX3 qui lui est supérieur en tout, toujours chez Audiophonics.
Niquel!
Je l'utilise depuis un mois en bluetooth. La connexion est rapide.
La qualité audio est top pour le prix, y'a rien à dire.
Seuls les presets d'eq posent question, l'affichage est très peu explicite et à l'écoute rien de flagrant...en tout cas sur les vieilles petites enceintes phillips que je fais marcher avec...
La puissance est au rdv
La puissance semble être au rdv, alimente sans souci des enceintes au rendement moyen (87 db/m/w), seul défaut un souffle assez important à faible volume donc ampli à éviter pour une écoute de proximité ou avec enceintes haut rendement. Sinon ce petit ampli est très polyvalent (usb/entrée ligne/bluetooth/sd) et pour un prix mini. Une dizaines de preréglages de tonalité possible
Utilisé pour une télé
Parfait, livraison rapide, bien emballé, bon fonctionnement.
Un petit préampli dans le même esprit avec réglage grave et aigu
serais plus que parfais.
Roland Singer.
The FX-Audio M160E is an amplifier capable of developing 2x125W under 4 Ohm. In addition, its Class D design allows it to benefit from high...
