FX-AUDIO XL01 Amplifier
The FX-Audio XL01 is a compact Class D amplifier with an integrated subwoofer output for passive subwoofers. This makes it ideal for integrating a small, affordable yet high-performance 2.1 audio system. Its amplifier stage is equipped with a CS8673E chip, delivering 2x40W + 1x75W of power. It is therefore perfectly suited to integration in a small or medium-sized listening room.
Reference : 18575
44,90 €tax incl.
37,42 € tax excl.
FX-Audio XL01 Amplifier Class D 2.1 CS8673E Bluetooth 2x40W + 75W 4 Ohm
FX-Audio XL01 : Vue principale
The FX-Audio XL01 is a compact Class D integrated amplifier with an integrated subwoofer output for passive subwoofers. This makes it ideal for integrating a small, affordable yet high-performance 2.1 audio system. Its amplifier stage is equipped with a CS8673E chip, delivering 2x40W + 1x75W of power. It is therefore perfectly suited to integration in a small or medium-sized listening room.
What's more, in addition to its volume control, the amplifier features a tone control for adjusting bass and treble levels to suit your taste, your system and your listening environment.
In terms of connectors, the XL01 is straightforward, with an RCA input and a speaker terminal output. However, it is equipped with a particularly practical Bluetooth receiver, enabling you to broadcast your music wirelessly from a smartphone or tablet, for example.
Product typeIntegrated amplifier
Amplification typeClass D
Number of channels2.1
Amplification chipCS8673E
Output power2x40W + 75W @ 4Ω
2x24W + 40W @ 8
InputsBluetooth
Stereo RCA
OutputSpeaker terminals
Speaker impedance4-8Ω
SNRL/R : 8dB
Sub : 100dB
THD+NL/R : 0.1%
Sub : 0.02%
Efficiency> 90%
Frequency response20Hz - 20kHz (±3dB)
Supply voltage19VDC (power supply included)
Dimensions98 x 142 x 33mm
Housing materialAluminum
Package1x FX-Audio XL01
1x Bluetooth antenna
1x Power supply
Channel2 (Stereo)
Channel2.1
Amplifier chipCS8673E
Power (W)40.0
un ampli a essayer absolument...et qui vous ne coutera pas grand chose
Très clairement, à 45€, je ne vois pas comment faire mieux. La finition est très bonne, avec des vrais boutons qu'on peut toucher. Pas de petite chinoise qui met une musique agaçante au démarrage (comme sur le BT60W), une connexion bluetooth qui marche bien et avec un vrai bouton là aussi.
Ce n'est pas le cas hélas des bornes HP, bien trop petites: sans fiches bananes, point de salut!
le canal grave est très bien géré et filtré, avec un petit caisson, c'est au poil!
Au niveau du son, je me suis amusé à le comparer au fameux BT 60W, vendu au même prix. Ce dernier est un peu plus doux, mais moins précis, la sonorité du XL01est un petit peu métallique, surtout par rapport à un ampli Hifi "classique". Prévoir en conséquences des enceintes un peu "molles". Enfin, au chapitre des désagréments, la puissance n'est pas au RV. Où sont les 24W annoncés? Mais dans l'ensemble, je recommande chaudement ce petit modèle au rapport qualité prix totalement imbattable.
This review has been posted for FX-AUDIO XL01 Amplifier Class D 2.1 CS8673E Bluetooth 2x40W + 75W 4 Ohm
The FX-Audio XL01 is a compact Class D amplifier with an integrated subwoofer output for passive subwoofers. This makes it ideal for integrating a...
