IEAST AUDIOCAST AMP50 Amplifier Streamer
The iEast Audiocast AMP50 is a connected amplifier that combines the functions of amplifier and streamer. It can deliver up to 2x 50W under 4 ohm thanks to a ACM3129A amplification chip, and can connect to the network via Wi-Fi or its ethernet RJ45 port. Bluetooth 5.0 functionality is also available for fast, stable wireless transmission.
Reference : 19625
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 22-04-2025.
iEast Audiocast AMP50 Amplifier Streamer 2x50W 4 ohm WiFi Airplay DLNA Bluetooth 5.0 24bit 192kHz
Photo of IEAST Audiocast AMP50
The iEast Audiocast AMP50 is a connected amplifier that combines the functions of amplifier and streamer. It can deliver up to 2x 50W under 4 ohm thanks to a ACM3129A amplification chip, and can connect to the network via Wi-Fi or its ethernet RJ45 port. Bluetooth 5.0 functionality is also available for fast, stable wireless transmission. The AMP50 can be controlled via the Audiocast APP Control, which features a wide range of settings. Multiroom operates in stand-alone or partition mode for greater flexibility. Connectivity is more than essential, with various digital inputs, a 3.5mm analog AUX input and a Phoenix terminal output. Numerous accessories are supplied for direct use of the AMP50.
Some Audiocast AMP50 streaming services
iEast Audiocast AMP50: a high-performance amplifier
The AMP50, as its name suggests, delivers up to 50W per channel at 4 ohms load. At 8 ohms, it can deliver up to 2x25W. Output is via a screw terminal block, and a screw terminal to banana plug adapter is supplied.
Audiocast AMP50 picture
IEAST Audiocast AMP50: a connected amplifier
iEast Audiocast AMP50: a connected amplifier
This AMP50 amplifier/network player features a 2.4GHz Wi-Fi connection for a fast, stable connection. This makes it easy to access your audio files, whether stored on a smartphone, computer or NAS. It supports AirPlay and DLNA/UPnP protocols.
iEast Audiocast AMP50: multi-room streaming
Combined with other Audiocast products, the AMP50 can be used to set up a multi-room system with two operating modes:
  • Stand-alone mode: stand-alone mode allows you to broadcast different playback tracks depending on your rooms.
  • Partition mode: partition mode enables all your speakers to play your music in sync..
Multi-room configuration with Audiocast products
Audiocast AMP50 Bluetooth features
iEeast Audiocast AMP50: Bluetooth 5.0
The AMP50 features a Bluetooth 5.0 receiver chip supporting the SBC codec for stable, reliable wireless transmission of your music via a smartphone, for example.
IEAST Audiocast AMP50 : Audiocast control APP
The Audiocast control app gives you access to all your streaming services, such as Spotify, Tidal, Deezer, YouTube Music and Apple Music, as well as to numerous Internet radio stations. The application also offers a wide range of settings, including bass and treble equalization for personalized listening.
AMP50 overview
Audiocast AMP50 connector interface
1Stereo output on screw terminal block
2Stereo AUX input on 3.5mm jack
3USB-A input
4Ethernet RJ45 port
512-24V DC jack power input
6Toslink optical input
7Pairing button
Product typeAmplifier / Network player
Inputs1x USB-A input
1x 3.5mm jack
1x Toslink optical input
WiFi
Bluetooth
OutputSpeaker terminals (Phoenix)
Output power2x50W @ 4 ohm (THD=1%)
2x25W @ 8 ohm (THD=1%)
Input sensitivity70mW @ (full power)
SNR< 0.1%
WiFiWiFi IEE802.11 b/g/n 2.4GHz
BluetoothBluetooth 5.0
Supported Bluetooth codecsSBC
Supported audio formatsAPE, FLAC, MP3, WAV, AAC, AAC+, WMA, ALAC, AIFF
Supported transmission protocolsDLNA, AirPlay, Spotify Connect, QPlay
Supported sample rateUp to PCM 24bit 192kHz
Ethernet10/100M
Smart Home controlTCP/IP
Power supply20V/3A DC
Dimensions136 x 134.8 x 40.1mm
Package1x iEast Audiocast AMP50
1x Adapter from screw speaker terminals to banana plug sockets
1x 3.5mm jack to RCA stereo cable
1x 3.5mm jack to 3.5mm stereo jack cable
1x AC adapter and power cable
InputWiFi
InputJack 3.5mm
OutputPhoenix connector
DAC / ADC ChipNC
Max sampling rate192kHz
Channel2 (Stereo)
Amplifier chipN/A
Power (W)50.0
Remote ControlYes
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
IEAST AUDIOCAST AMP50 Amplifier Streamer WiFi AirPlay DLNA Bluetooth 5.0 2x50W 4 Ohm 24bit 192kHz
The iEast Audiocast AMP50 is a connected amplifier that combines the functions of amplifier and streamer. It can deliver up to 2x 50W under 4 ohm...
