LITTLE DOT LD-4P1S Tubes amplifier / Headphone amplifier 2x8W 8 Ohm
The Little Dot LD-4P1S is the perfect solution for experiencing the warm sound of a tube amplifier, combining modernity and vintage. It serves both as an integrated amplifier and a headphone amplifier.
By buying this product you get 169 loyalty points
Reference : 17775
1 699,00 €tax incl.
1 415,83 € tax excl.
Last items in stock !
Shipping date: 18-04-2025.
LITTLE DOT LD-4P1S
Tube amplifier / Headphone amplifier 2x8W 8 Ohm
LITTLE DOT LD-4P1S Amplificateur à tubes / Ampli casque 2x8W 8 Ohm
Flexibility
With a power output of 2x8W RMS at 8Ω, the LD-4P1S provides sufficient power for integrating a small to medium-sized high-end HiFi system. Additionally, it offers high-quality headphone listening experience with its two built-in headphone outputs on the front panel of the unit.
A simple and efficient connection
The Little Dot LD-4P1S is equipped with a stereo RCA input as well as a balanced stereo XLR input. In terms of output, it features speaker terminals for connecting speakers, as well as two headphone outputs: one in the form of a balanced 4-pin XLR and the other in the form of a single-ended 6.35mm (1/4-inch) jack.
Technical Characteristics
Product typeTube Amplifier
Headphone Amplifier
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
OutputsSpeaker terminals
1* Balanced XLR 4 pins headphone output
1* Single-ended Jack 6.35mm (1/4") headphone output
Tubesx6
Power2x8W @ 8Ω (speaker terminals)
3W @ 120Ω (headphone output)
1W @ 300Ω (headphone output)
SNR98dB
Frequency response20Hz - 20KHz (-0.2dB)
10Hz - 50KHz (-1dB)
Distortion0.1% (1000Hz)
Fuse250V 2A (size: 5*20mm)
Power voltage110V 60Hz
220V 50Hz
Dimensions340*290*145mm
Weight8.9kg
ColorGrey / Black
Package1* Little Dot LD-4P1S
1* Power cable
1* RCA-RCA cable
1* 6.35mm jack to 3.5mm jack adapter
1x Fuse (inside the IEC socket)
InputXLR
OutputSpeaker terminal
OutputJack 6.35mm
ColorSilver
Channel2 (Stereo)
ClassTube amp
Amplifier chipTube
Power (W)8.0
The Little Dot LD-4P1S is the perfect solution for experiencing the warm sound of a tube amplifier, combining modernity and vintage. It serves both...
